OIL!
12 posts • Page 1 of 1
Surely Mobil 1 15w-50 Fully Synthetic Oil has got to be the gear to use!<br><br>If it's good enough for the Maclaren Formula One team and Boeing 777 aircraft, then it's definitely good enough for any roadcar without a shadow?
- Paul Taylor
- aka 'The Gachet'
yeah, but my fiesta engine aint made by Pratt & Whitney! LOL <br><br>The zetec needs a faily low viscosity oil at both hot and cold temperatures to help prevent sticking valves in the cylinder head. Although on the early models this was a bit of a problem, it can be helped grately by using a 5w oil. Agree with the fully synthetic though.
- Andy_XR2i
5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,5W-30,
- passion
0W-30 is just too thin for a Ford engine for now - maybe in a few years when engineering tolerances have decreased a bit.
We use Castrol 5w-30(mineral) at work and is recommended by ford. I`ve stripped engine with 100000 miles on then and there is hardly any wear in the engine, bores are near perfect. 0W-40 should be o.k as zetecs are pretty oil tight. Depends on how hard you thrash the engine!!<br><br>
- snake
- Trainee Burger Flipper
- Your car: ford
Listen lads its all about vescosity wright<br>0w-40 is probably about the best oil there<br>is to put in your motor,and it doesnt piss out of oil seal's because they shoudnt leek anyway and us with slick 50 is perrrrrrrrfect<br>make sure you use fully synthetic
- HAMMER26
