Opinions wanted: standard or upgraded master brake cylinder
24 posts • Page 1 of 1
Hi there,
The Fiesta (mk3) modding virus has hit Holland :-p
I've already modded my brakes 2 years ago, but now some fellow modders are wanting bigger brakes too.
No problems around the brakes themselves.. they go for either cossie setp or RS2000 setup.
But.. some questions arose around the Master brake cylinder..
Uprated or standard is the question..
Your opinions .. with arguments please (-:
- Jur
For starters.. my opinion .. and argument.
Standard brakes .. 240mm ..
Standard master brake cylinder
pedal-travel (hypothetically) 2"
Weight of the MK3 914kg
Uprated brakes (RS2000) 260mm
Standard brake cylinder
pedal-travel (hypothetically) 2,5"
Weight of the car 914kg (might be 915 due to bigger brakes :-p )
Uprated brakes (Cos4x4) 278mm
pedal-travel (hypothetically) 3"
Weight of the car 914kg (might be 916 due to bigger brakes :-p )
uprated (rs2000) brake cylinder
Uprated brakes (cos4x4) 278mm
pedal-travel (hypothetically) 2,25"
The cars weight stays nearly the same.. so the needed stopping power remains the same.
You can get locking brakes with JUST the 240mm brakes.... so the brake power itself is not the issue.
The problems (IMHO) lies with the endurance of the 240mm brakes (the time it cope under full braking power)
The 260mm brakes can cope longer.. and the 278mm can cope even longer.
the (maximum) braking power of the 260mm setup is greater than that of the 240mm .. and 278mm has even greater breaking power
So.. you don't have to push down the pedal as hard on a 260mm or 278mm to obtain the same brake-power as the 240mm.
If you use an uprated master brake cylinder with an uprated disc setup you have (nearly) the same pedal travel compared to the standard cylinder and standard disk setup. But also more chance of getting locking brakes.. because the "feel" is more restricted.
IMHO .. i have myself a standard brake cylinder on my cossie4x4 setup .. which gives me more pedal travel.. but if i press the pedal to the same 'depth' as the standard setup.. i get the same braking power (which hold better than the standard 240mm does :-p ) .. if i press the pedal furhter i even have more braking power. .. the pedal feel is greater that that of the uprated discs + uprated master cylinder..
So .. i go for standard due to better pedal feel .. without los of braking power.
greets
greets
- Jur
I dont see why the std master cylinder wont cope, what would be a good upgrade is to make sure the cylinder does NOT flex or move when the brake pedal is being pressed. A bracket to hold the master cylinder in place would increase braking a lot.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
with a LHD fiesta you don´t have as much ´flexing´ of the brake cylinder due to the direct connection to the brake servo.. in stead of thru a beam
- Jur
Mizka :^Only postman pat drives on the "wrong" side around here
lol .. we drive on the Right side of the road.. :-p zo the left side.. is the wrong side..
the right side could never be the left side :-p
- Jur
Yeah no doubt
How about that master cyl swap from Esco RS2000? Is it a bolt-on swap or is there something more to it? How about big engine Sierras, are there any compatible/more jerk units?
Don't mind the servo cause I'm not gonna use it (rally car).
It's better to burn out than fade away
- Mizka
Contact XRSi mate. I'm sure he does uprated setups from an Escort MkV. You use the master cylinder and servo and they 'pretty much' fit straight on.
Dave
Dave
Area 6 355bhp monster!
- CarismaDave
CarismaDave :Contact XRSi mate. I'm sure he does uprated setups from an Escort MkV. You use the master cylinder and servo and they 'pretty much' fit straight on.
Dave
they do fit straight on!
- xrsi
- XR(ustyAtTheMo)SI
xrsi :CarismaDave :Contact XRSi mate. I'm sure he does uprated setups from an Escort MkV. You use the master cylinder and servo and they 'pretty much' fit straight on.
Dave
But are they better!?
" San Diego... German ofcourse, meaning 'A Whale's Vagina' "
- scarlet_pimp_mobile
- Location: Hurst Green, East Sussex/ Constitution Hill, Swansea
A lot lot better, my pedal went spongy as hell and i had to stamp it to the floor before the brakes came on properly after fitting my ST170 front brakes and braided lines.
Swapped to the escort master cylinder and it solved the problem straight away. Don't have to press the pedal down half as far as before and the pedal feel is sooooooooo much better.
Highly recommended and relatively cheap mod
- CRF
CRF :A lot lot better, my pedal went spongy as hell and i had to stamp it to the floor before the brakes came on properly after fitting my ST170 front brakes and braided lines.
yeah same as me mate
when i fitted my st170 brakes my brake pedal travells alot more then b4
does changing the master cylinder really sort this
- Mikee_RS
Car: 1995 Ford Fiesta
- fiestasi1800
TRP :Bigger diameter master will always reduce the pedal travel and give the brakes a more direct feel.
Does any one know what size wheels you have to use to clear the RS2000 and 4x4 callipers? Thanks
15" minimum .. and watch out.. the Cosworth calliper might catch on the spokes
- Jur
Hmmz..oke.. had some replies..
till now.. the intermediate results
when going ST170 (300mm) an upgrade is advised..
When goind cosworth 278mm .. it's your personal choice
when going rs2000 (260mm) it's not needed.
- Jur
good advice on brakes here
Hey Jur when you getting your festure mate ?
Lower than a snakes bollox
- Big Walker
- Your car: Seat Ibiza
woops LOL when are you getting your fiesta featured ?
- Big Walker
UncleFesters69 :woops LOL when are you getting your fiesta featured ?
FF have planned to visit the nurburg ring (which is open from 13th of april .. .. and i guess on their way back they will visit holland.. (sunday april 16th)
Hope they don't skip it like last year september.
Already picked some nice spots.. not gonna tell though..
- Jur
