overboosting
20 posts • Page 1 of 1
overboosting
i have i xr2i with a rs turbo conversion.the engine was out of a fiesta.i have a boost gauge and a boost contorler.it runs 6psi fine but as soon as it goes over 6psi the boost jerks on and off.
can someone plz tell me what i could do to run more boost.i have low comp pistons and a t3.so whats the most i can run??
- SEG1
As you hav'nt stated you have a chip, you will only be able to run 9psi tops before the boost protection cuts in from the ecu, fitting a chip will get over this problem and you can turn the boost up, BUT make sure your fueling is matched to the increased boost preasure, else bye bye pistons
I suggest you go for a "195" chip, beige injectors and an cossy fuel pump as you have low comp pistons so you should be able to run at least 15psi, again make sure its all set up properly, that way you will avoid any nasty surprises.
HTH.
Gareth.
HTH.
Gareth.
- black2
As above if you have a cheep boost gauge they some times's can be 3-6 psi out so it could be over boosting before you thing
- j7aoc
- SEG1
i have just found out that i have beige injectors and a 195 superchips' chip in my ecu.its a plug and play chip.and im still over boosting.
what could be wrong?
- SEG1
I would try taking out the chip but don't drive it hard just to see if it's over boost. Don't mess with the chip when the Ignition is on other wise it damage your ECU. What boost gauge do you have? if it's cheap like those one's that change colour then bin it
- j7aoc
- SEG1
Bin it and buy a auto meter or nomad new there about £50-60 second hand £30ish. try taking the chip out like i said if nojoy then adjust the actuator turn the stem so it get's longer a few turn's at one time that will lower the boostRS_seg :yep it changes colour!!!!
pink blue red green and white lol
- j7aoc
- SEG1
You will need to have it maped and fitted £700-£1000 My car run's on the standard loom and ecu just have a chip that is mapped and it should do 220-260bhp it's running 20psi What is you engine spec?RS_seg :i just bought a level 6 ecu and the loom if i fit this will it defeat this problem?
- j7aoc
beige injectors
195 chip
low comp pistons
Kent cam 35
stage 2 head
blueprinted bottom end
i dont no about the fuel pump how can i tell if its uprated?
195 chip
low comp pistons
Kent cam 35
stage 2 head
- SEG1
The escort cosworth fuel pump is identical to the frst so you can't tell them apart but you will need the cossy one or uprated one as it need's to keep up with the chip/injectors as your engine will go bangRS_seg :beige injectors
195 chip
low comp pistons
Kent cam 35
stage 2 head
- j7aoc
- SEG1
- j7aoc
- SEG1
Sorry it's under the back seat you can see it if you take it up but to take it out you need to get under the car and drop the fuel tank down to get it outRS_seg :i mean in the engine .
- j7aoc
- SEG1
I swaped mine for a gen ford cossy and there's no way to tell them im not sure if there's apart number you could ring ford's and ask them for a part numberRS_seg :ok thanks.will it have any codes on it?so i can tell if its a cossie or fiesta
- j7aoc
- SEG1
Clean the chips conatctas along with those on the ECU using a non abrasive contact cleaner (Electrolube etc) then refit the chip. The chips themselves are rarely at fault so it may be worth speaking to a reputable tuner for advice if this doesn't cure it
