Overheating issue
6 posts • Page 1 of 1
Overheating issue
Hi Guys,
Having just received my FRST back from a local garage for an MOT (failed - wheel bearing) Which i was very impressed considering the age of the car (H-Reg)
A full coolant (Black) Roose set has been fitted & the car was running great until I drove it on the motorway. I didn't hit the speed limit of 70 just to be safe i kept the Fiesta at 60.
All of a sudden the temp gauge started to climb BIG style. In the red. I pulled over & could see steam coming from the brand new plastic header tank. The water was bubbling.
Having now got the car at home I let it cool & removed the header cap. Zero water. I have now filled the header tank to the max line & left the cap off & the car idling.
The water level started to rise. I have read on a few sites (this one included) that I could have an air lock.
Also the heaters do not work. They did not work before the above work was undertaken.
Any ideas?
Thanks.
Any ideas?
Thanks.
- AR-FRST
- Your car: Fiesta RST
Re: Overheating issue
sounds like an air-lock to me mate, also it sounds like your heater matrix could be blocked, this could be causing the airlock
- Dave5300
Overheating issue
I concur try a good flush and reverse flush
- willowandmikey
willowandmikey :I concur try a good flush and reverse flush
Reverse flush?
- AR-FRST
Overheating issue
Flushing not just from the header tank but flushing by inserting a hose lower down in the cooking system
- willowandmikey
Overheating issue
Cooling
- willowandmikey
