Owners with 300bhp+ - tyre choice
18 posts • Page 1 of 1
What tyre sizes and brands have you used and what is your opinion of them?
Re: Owners with 300bhp+ - tyre choice
Awaits jonyb4 jokes.......................
- Ratspeed
AO48R'S
- luca
luca uses r888's i think or MT slicks recently
although not in the same league
i had yokohamma a048's medium compound on my 106 track car,
which is the same used on the lotus exige
found them great, allows you to push your confidence with the car alot more,
traction was better, you knew when they were up to temperature....................
can hear them picking up all the crap off the road
- RS rob
Wrong forum
On a serious note, I don't know.
Got Falken FK452's on the 540i as recommended by people on pistonheads. Totally different car though.
Toyo T1's or Eagle F1?
toyo's???????
i used to respect you max!
- RS rob
Thanks all - I will have to try these AO48R's!
RS rob :toyo's???????
Have used them on loads of cars, my mate had them on a 230bhp ERST and currently has them on his TVR T350 and all fine.
Ratspeed :Awaits jonyb4 jokes.......................
Jony uses Nankangs if that helps.
- EUFez
EUFez :Ratspeed :Awaits jonyb4 jokes.......................
Oh my days.
But on a serious note, I have heard good things about AO48R'S too from various sources.
- - Danny Boy -
- Your car: Fiesta Si 2.0
888's are great initially over a normal road tyre.
However I found when on track these would overheat and go off after about 3 laps.
A set of Ao48r's came up so I thought try them. These were in 205/50/15" they were leagues ahead of the 888's.
As Rob stated I also use now the M/T drag slicks which are huge and needed alot or arch mods !!!!!
and erm...which erm!... well killed my clutch
- luca
Max M4X WW :RS rob :toyo's???????
fair enough if they've been great for you,
they've got a bad repuation among my mates,
most of them are on yoko's, goodyear and conti's
- RS rob
im using maxi maz1s on my car been great on the roads unsure on track tho but im not running 300bhp either just another tyre to consider.
- simps
Christ Luke, is that a C20LET Helix 6 Paddle?
Excursion :Christ Luke, is that a C20LET Helix 6 Paddle?
Clutch Masters setup from America that was only 20miles old too
- luca
luca :Excursion :Christ Luke, is that a C20LET Helix 6 Paddle?
What's it rated to? Looks like I'll end up with 450 now so need something decent!
Are you using a Fidanza flywheel or similar?
Meant to handle 500hp.
You best get a twin plate clutch if you want a fit and forget solution.
- luca
i use dunlop direzza o3g. probably the best semi slick tyre out there!
but very expensive £140 for one 205/50/15
- SEG1
