P Reg Turbo Conversion Update 12/07/13
Re: P Reg Turbo Conversion Update 28/7/12
Postby P-reg-Turbo on Fri Aug 03, 2012 9:06 pm
georgiocat :Good work.So what was the reason for stiff rotation of the camshaft in the head...?
I dont know, i have given it to a friend of mine who builds engines, still waiting to get it back
P-reg-Turbo
Your car: P Reg Fiesta RS Turbo
Postby P-reg-Turbo on Tue Nov 20, 2012 10:16 pm
Right i havent updated for quite awhile as been really busy, but things are going into place now, heres is a photo of the engine with the camshaft being dialled in
then finally i got the engine and box bolted into the car on monday, just a case of connecting everything up and getting the last few bits i need to get it running
P-reg-Turbo
Re: P Reg Turbo Conversion Update 19/1/13
Postby P-reg-Turbo on Sat Jan 19, 2013 6:39 pm
Just a quick update, had the car running for a while now, still waiting for an actuator from Julian Godfrey's, but 2 lots of bad news, i have to take the gearbox out as the diff bearings are fcuked and also when the car has warmed up slightly it starts steaming out of the exhaust, i just hope its either the turbo or water in the exhaust, 99% sure it isnt the engine
P-reg-Turbo
Re: P Reg Turbo Conversion Update 20/11/12
Postby russ-RST on Tue Jan 22, 2013 8:18 pm
glad to see your still cracking on with this :) looks good progress what turbo are u running it on? if u still need a actuator I have a -31 one for t2 I can sell ya? works fine im just converting over to t3 at he moment , if u suspect that your turbo is leakin water into the exhaust there's an easy way to tell... take the water feed ad return of the turbo and stick a bolt in the hoses ad see if it still does it.. it's a hell of alot more fun to drive than the 1.3 ain't it :lol:
russ
russ-RST
Your car: fiesta rs turbo
Postby P-reg-Turbo on Tue Jan 22, 2013 10:29 pm
russ-RST :glad to see your still cracking on with this :) looks good progress what turbo are u running it on? if u still need a actuator I have a -31 one for t2 I can sell ya? works fine im just converting over to t3 at he moment , if u suspect that your turbo is leakin water into the exhaust there's an easy way to tell... take the water feed ad return of the turbo and stick a bolt in the hoses ad see if it still does it.. it's a hell of alot more fun to drive than the 1.3 ain't it :lol:
russ
Thanx for the offer, I am running a T3, got the actuator on order, not driven it on the road yet, got to get the box done first, but at the moment funds are all gone,
Here are a few photos, i need to paint the intercooler black, looks very stealth
P-reg-Turbo
Postby Michael! on Wed Jan 23, 2013 11:34 am
brilliant sleep this! looks like s**t goes like s**t :D
(not saying it looks like s**t, you get what i mean) :lol:
ft-com-members-map-vt190192/
Michael!
Postby P-reg-Turbo on Thu Jun 20, 2013 12:07 am
update time as i havent done much since january, well after having it driving round the forecourt at work i noticed a gearbox oil leak, gearbox i brought as 'working' has knackered diff bearings, after removing the gearbox and stripping it down i find this
absoluety f**cked, so i brought a box of scrap, anyway went to see my local gearbox guy, he goes through a few boxes and finds a pinion shaft and crown wheel he had made up, it has an uprated bearing pinion bearing (mt75 one) and a slightly different ratio, old one was a 3.8, new one is a 3.5 so a better top end, anyway at the moment i am trying t find time to finish rebuilding th ebox and get it back in the car, once its back in a few small jobs on it and hopefully its ready for getting it set up correctly
P-reg-Turbo
Re: P Reg Turbo Conversion Update 20/06/13
Postby Rs Adz on Sun Jun 23, 2013 7:16 pm
coming on well
Rs Adz
Your car: xr2i and mk1 fiesta
coming on well
Rs Adz
Postby P-reg-Turbo on Fri Jul 12, 2013 1:10 pm
well ive rebuilt the gearbox with new bearings, gaskets and seals, all back in the car, had it running, now i seem to have a water problem, bloody water is rising out of the header tank, and boiled up, this is after i totally rebuilt the engine, so they is proburaly a crack in the head or block, anyway i am currently off work due to an op on my ankle and laid up for a month or 2
P-reg-Turbo
Previous
