painting tips
painting tips
Postby iain6790 on Fri Jul 16, 2010 10:50 pm
hello guys after along winter of boring body work the day has finally came to paint my rs. i wil be starting it tomorro and i have never sprayed a car before so i was wondering if any1 had any tips dos and donts that kind of thing cheers
iain6790
Re: painting tips
Postby leighk2010 on Sat Jul 17, 2010 12:15 pm
dont rush it take ya time with nice thin coats and get a good overlap, also as you come to the end of your stroke flick the spray gun.
leighk2010
Re: painting tips
Postby iain6790 on Sat Jul 17, 2010 1:46 pm
ryght thanks. i have just finishd priming the car and there is like the odd bobbly bit in it what can this be with
iain6790
Re: painting tips
Postby DanFraser on Mon Jul 19, 2010 12:43 pm
The old saying "Two thin coats is better than 1 thick coat" apply like crazy here.
With the bobbly bit, I would suggest using 2000 wet and dry to gently take it down. This will also highlight if the surface below hasn't been prepared properly.
DanFraser
Your car: Ford Fiesta SI 1.6
Re: painting tips
Postby SammyBoy_01 on Mon Jul 19, 2010 1:45 pm
take lots of photos of the process and post :)
SammyBoy_01
Re: painting tips
Postby iain6790 on Mon Jul 19, 2010 4:36 pm
cheers for the advice lads the bobbly bits got sorted with wet and dry and my top coat came out amazing. i was going to paint it diamond white again but i went with frozen white instead so glad i did it looks so fresh just for the big build now lol :D
iain6790
Re: painting tips
Postby blacksheepdesigns on Thu Aug 19, 2010 8:14 pm
99% of a good paintjob is down to the prep work, prep, prep and prep some more, can't do enough prep work, the painting is the easy bit
blacksheepdesigns
