Pedal set . help pleeeze :)
Postby Phil Si on Mon Mar 12, 2001 10:15 am
hi. i purchased a pedal set.<br>however when i took off the clutch rubber cover. i found a big square hole. obviously, if i put a bolt tru it, the bolt would fall thru.<br>and even if i used a washer the other hole that i would have to drill wouldnt fit on the bit of metal.<br>sooooooooo.......<br>my idea, probly a dumb one, is. can i stick them on using the sort of double sided tape that people put their number plate on with?<br>aaand, would it be better to stick it onto the normal rubber bit or onto the metal?<br>one more thing. i tryed putting my handbrake cover on. the bar is way smaller on my handbrake to teh cover for it. and the grub screws fall inwards. so i FORCED it on and it is squeazed on abit of the metal past the normal bar bit. not 100% but does the job. i put 1 of the screws in, as the otehr fell inside.<br>Did anyone else have this problem, and if so how did you sort it <IMG SRC="http://www.v8fiesta.co.uk/ubb/smilies/smile.gif"><br>Thanks peeps<br><br>Phil <IMG SRC="http://www.v8fiesta.co.uk/ubb/smilies/biggrin.gif">
Phil Si
Crack Smoker Of The Year 1999
Car: 2000 BMW 330 Ci
Postby Andrew Malcolm on Mon Mar 12, 2001 10:24 am
No Double Posts Please <IMG SRC="http://www.v8fiesta.co.uk/ubb/smilies/smile.gif"> <br><br><i> A riddle Wrapped in an Enigma Hidden Behind the Fridge</i><br><br>
Andrew Malcolm
