plan... :P
14 posts • Page 1 of 1
plan... :P
right then peoples
ive managed to get hold of an xr2 engine for my mk3 festa... hasnt been turned over in 3 years or summit silly like that.. so ill prob re-build that myself.... anyways
im currently running a 1.1 so the brakes with this new engine in will be awful... what doi you lot reccomend me getting
bearing in mind im on a tight budget.. i got the xr engine for £70 lol
- xmadxmoex
upgrade to any of the vented brake combos, Xr/turbo/si, a lot better when compared to the non vented ones
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
ive got some rst calipers and groved disks, wouldnt want much for them, but i can see postage being silly.
- muz
i dont think the rears are different, i could be wring though
JJ
JJ
- jdfiesta
- Your car: V70 T5
jdfiesta :i dont think the rears are different, i could be wring though
JJ
Rears a bigger on Si/FRST/XR2i than on "Base" models.
Front brakes
Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Solid or ventilated disc, with single-piston sliding calipers
Disc diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 240.0 mm
Disc thickness:
Solid disc . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.0 mm
Ventilated disc . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.0 mm
Minimum disc thickness:
Solid disc . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.0 mm
Ventilated disc . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18.0 mm
Maximum disc run-out (disc fitted) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.1 mm
Minimum brake pad thickness . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 mm
Rear brakes
Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Drum with leading and trailing shoes and automatic adjusters
Nominal drum diameter:
All except XR2i and ABS equipped models . . . . . . . . . . . . . . . . . . . . 180 mm
XR2i and ABS equipped models . . . . . . . . . . . . . . . . . . . . . . . . . . . . 203 mm
Maximum drum diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0 mm above nominal diameter
Wheel cylinder bore diameter:
All except XR2i and ABS equipped models . . . . . . . . . . . . . . . . . . . . 17.5 mm
XR2i models with conventional braking system . . . . . . . . . . . . . . . . . 19.0 mm
All ABS equipped models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22.0 mm
Minimum brake shoe lining thickness . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0 mm
- Liebo
