Please can someone explain how power boost valves work
17 posts • Page 1 of 1
my engine is having work done to it and it has been suggested that i buy a power boost valve to help the performance. i dont have a clue how these work and what the benefits from using them are.
also would they work well with a swirl pot which will most probably be going on the car?
thanks
thanks
- S2
Power boost valves replace the standard fuel pressure valve that regulates the fuel pressure to the injectors. The power boost valve will allow greater fuel pressure through than the standard item (perhaps around one and a half times the amount you were getting), so you will get better throttle response and acceleration.
HTH
James.
HTH
James.
This for a Series II ? you dont get power boost valves for MFi as you dont have a fuel rail and injectors. I think your tuner or who ever has been telling you porkies.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
They do actually claim that you wont use more fuel (unless you have a lead right foot) and the pressure is 1.7 times greater. (just bought one so I read the box)
Just Remember - A woman worries about the future until she gets a husband,
a man never worries about the future until he gets a wife!!!
- Mike
From what i rad they dont increase the pressure the system runs at. when engine is bieng run has one pressure. Then has a lower pressure for when engine is idling. Then when ya put ya foot down the pressure comes back up to the standard. The boost valve just brings the pressure back up faster than a standard item.
- tonydude
The fuel pressure regulator DOES control the fuel pressure at the fuel rail and injectors.
The FRST already has an adjustable regulator, so you do NOT need a FSE valve.
The FSE valve is set to increase the fuel pressure by 1.7 and cannot be adjusted which is not good if you increase your boost pressure.
Save your cash for something u will actually need.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Phil Si
Car: 2000 BMW 330 Ci
