Please look if your arches rub on bumps
Postby PUREtom on Fri Apr 08, 2005 12:19 am
I have solved my problem of my arches rubbing at the rear because of my focus brake set up.
Basically I had a focus rear brake conversion on my car, and the wheels stick out so are dead level with the arch, so it rubbed (a lot) going over humps/bumps, with 5 people in scrubbed constantly, and round corners was a nightmare with even 3 people in.
It helped a lot by rolling my arches, but I still got a little rubbage.
Now the solution I found was suggested by Pez, thank you so much. I asked about if there was any rubber bit that sits in the coils, he suggested Grayston spring assisters. So I searched and found these:
http://www.springassisters.co.uk/
Now I put these in tonight, the ride height isn't affected, but oh my god what a difference, I got no rubbing with 4 people in, down the bumpiest road I could find! Absolute bargain for £18, its saved my arches from rust!!
This could solve rubbing on 16 inch wheels maybe?
And I do believe the handling is slightly improved as well, it feels a little stiffer, and takes the bumps better!
Tom
PUREtom
Postby RS_Rawli on Fri Apr 08, 2005 9:35 am
they do make it sit slightly higher, i had to get some of these for the front of mine when i fitted the turbo as it made it undriveable, i do believe that they weaken up though as its started scrubbing again
RS_Rawli
Postby PUREtom on Fri Apr 08, 2005 9:49 am
How comes you needed to fit them on the front? Was the engine too heavy? Surely some RS1800 springs would have been adaquate??
PUREtom
Postby RS_Rawli on Fri Apr 08, 2005 9:55 am
it had RST springs on it, was alright on 15s, when i put it on 17s it sat perfect with the 1.1 in, put the turbo in and it left the wheel (not the tyre) inside the arch, so had to put em in, they ahve been in a bout 18months though so maybe i have to get some new ones
RS_Rawli
Postby Pez on Fri Apr 08, 2005 10:05 am
Ah excellent news, glad to be of help :)
Pez
Postby Syorme on Fri Apr 08, 2005 6:39 pm
What was it you exactly got fella as i have scrubbage without it being lowered and will be looking into this
Syorme
Postby Badgerboy on Fri Apr 08, 2005 7:45 pm
Which specific spring assisters did you buy?
Also, how much stiffer are they? My setup is quite stiff anyway, so I don't want to bite my tongue off on every bump! I'm running 15" alloys with 195/45 tires, on a 50mm drop.
Hope these help save my Eagles F1's though!
Badgerboy
Postby James-UK on Fri Apr 08, 2005 7:57 pm
Yeah, what sort did you buy?
I've got the big ones that you have to soften with hot water which have a lip in the top & bottom which push fit into a coil of the spring?
Or the sort thats like a 1cm square of rubber which is bent into a coil shape then cable tied in place?
I used to have the first sort in the rear of mine but found it to stiff and tail-happy with my standard tyres. Now've i've got some big alloys on it the handling is nice but under hard cornering the front tyres rub the arch in which case they would be ace on the fronts, however it does say on the packaging of mine not to be used on front suspension?
James-UK
Location: Cornwall Drives:Whatever is outside at the time.
Postby PUREtom on Sat Apr 09, 2005 12:14 am
You have to measure your spring to decide what type ya want.
PUREtom
Postby javablu on Sat Apr 09, 2005 12:17 am
I take it you just ring that number to order, Tom? :D
javablu
Postby mike_wall15 on Sat Apr 16, 2005 4:30 pm
So you can use these on the front and back? Or is it recommended only on the back.
Also, do I need these ones:
Rubber Coil Spring Assisters Per Pair
GE13 £18.99 Inclusive of VAT P&P UK ONLY
GE14 £18.99 Inclusive of VAT P&P UK ONLY
GE15 £27.00 Inclusive of VAT P&P UK ONLY
GE15A £29.00 Inclusive of VAT P&P UK ONLY
Cheers :Q
mike_wall15
Car: 2002 BMW M3
Postby PUREtom on Sat Apr 16, 2005 5:28 pm
Yeah, measure the space between your coils when jacked up, then see what assistors you need.
I think rawli used some on the front, can be for either, works exactly the same.
PUREtom
