Popular Plus - 04/02/14 - Page 19 - The End!
Re: Popular Plus 16v - 22/07/10 - Page 11 - Hunting Idle Cured
Postby MK2 Jamie on Fri Jul 23, 2010 2:40 pm
Are you doing the 0-60 this year simon?
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby jonyb4 on Fri Jul 23, 2010 3:39 pm
funny enough my 18 does that hunting in the same way, but im using my old 1.3 hcs lambda lol
probs not the best idea, how much was the new lambda simon? :)
Postby Excursion on Fri Jul 23, 2010 4:10 pm
jonyb4 :funny enough my 18 does that hunting in the same way, but im using my old 1.3 hcs lambda lol
Nope, totally different.
Postby jonyb4 on Fri Jul 23, 2010 4:37 pm
lol thought as much, was better than nothing at the time, mind no excuse for not sorting it after 4 months :rolleyes:
ill replace that before the maf, which i originally thought was the problem
Postby Smo on Fri Jul 23, 2010 8:40 pm
Mr. Excursion - That is something I should have thought about actually, I had read in the past that the lambda sensor isn't used at WOT, but I didn't realise it was only used up to 3K. Hopefully it still explains my appalling around-town fuel economy though :lol: The idle is absolutely spot on now though and it does seem to be driving slightly better on light throttle when cold which was always a little dodgy. So I don't know if it was down to just the heating element, or a combination of probably a knackered sensor and the heating element. I did remember today when I was running my MegaSquirt a while back that the lambda reading did keep dropping out at certain times... Probably should have looked into that :lol: God, I'm useless :) I'll buy a decent wideband when I stop spending breaking gearboxes and I'll just run the MegaSquirt :lol:
Jony, I got it at a staff price through work, I'm not sure what they normally go for. To be honest, there's a huge range you can use on these ECUs because most of them are the same sensor with the same connector, just different wire lengths. I went for the cheapest one at staff price which happened to be an Escort 1.8 16v one which my ECU is from anyway :lol: I could have got one cheaper on eBay, but it's just easier through my work because I can take it back if I didn't need it or if I get a problem. It's a Fuel Parts item, which even though is an aftermarker supplier, we've never had any problems with any of their products in all the time we've been dealing with them :) From a business point of view also, they offer excellent technical support :D Anyway, I'm waffling now...
With regards to your sensor, it should be fine actually (assuming it's working fine), unless Mark knows something different, as it's the exact same sensor that we supply for most of the early Zetec Mondeos, in both NGK (NTK) and Fuel Parts. But nearly all narrowband sensors work the same, as far as I'm aware!
As Mr. Minstral has pointed out, I forgot to mention I've also finally gotten round to fitting my rear Koni adjustable shocks :lol: I've only had them since last year or something! I've been running front adjustables and springs all round, but still running on some standard rear XR2i shocks... So Tuesday, for some odd reason, I decided to fit them as I wasn't doing anything else. Oh, and because Toby was encouraging me to do so. One photo:
With the help of my very helpful neighbour, I also got the tracking sorted out the other week too... Again, only one photo, and a bit of a useless one at that:
... yes, we did it in the road, and a slightly uneven road :lol: But the tracking does seem to be spot on now, though :) It was sooooo far out, but I've recently changed the arms from standard 1.1 arms to XR2i 16v ones. I don't think that was entirely the reason the tracking was so far out, but I do think they put it out slightly more than it was. I can now put my foot down on quite dodgy roads and it keeps nice and straight, instead of wanting to throw me all over the place :D
And lastly, I can't remember if I posted up a photo of the damage done when someone ran into the back of me in December, but here we go:
Nice and folded boot floor :lol: :( I might sort it out one day...
Smo
Postby Smo on Fri Jul 23, 2010 8:42 pm
Oh, and yes Jamie, I will be, although I don't think I can get close to what I got last year... Car's just not well enough now :lol:
Next year, though... It will be in the 5s :D
Smo
Postby jonyb4 on Fri Jul 23, 2010 9:25 pm
haha, tbh id still rather a zetec lambda, i mean the one in it now is from a 97 mk4 1.3 endura hsc engine, fitted to a 97 1.8 mk6 escort engine running on a 92~ mondeo blob 1.8 ecu haha
might just fit the 1.6 one fromt he Si to it when the 1.8 goes in the Si
odd i know, but i really love how you sound when you talk lol, its calming and harmless if you get me :P
you seem a cheery person
Postby dontpannic on Fri Jul 23, 2010 9:36 pm
Smo :And lastly, I can't remember if I posted up a photo of the damage done when someone ran into the back of me in December, but here we go:
Identical to mine, only less rust.
Postby Smo on Fri Jul 23, 2010 9:41 pm
Awwwwwwww, thanks :bonkers:
I take it the lambda sensor from your 1.3 is one with the square plug and not the round plug? If so, it's definitely the exact same sensor that would have been used on a BLOB ECU :)
The idling issue could be the same as mine, or it could be something else. Could well be worth just testing your ECU with the 1.6 one from your Si, but then if your Si is working fine, best not to touch it and bugger it up :lol: (Not saying you would! :) )
And Nick, yeah, it wasn't rusty, I just never did anything about it. It gets used and abused and the bare minimum done to the bodywork now :lol: I might clean it up and protect it, but leave the actual metal work as it is... Really don't know at the moment :lol: Once my runaround 1.1 goes and I get something more modern and diesel, then I'll start working on it properly. Want to put another engine and gearbox in before I sort the bodywork out, though :D Priorities!!!
Smo
Postby hb69 on Fri Jul 23, 2010 9:45 pm
Not running the ms for ff?
SKINNY WHEELS :D
hb69
Your car: Fiesta 1.1 LX
Postby dontpannic on Fri Jul 23, 2010 9:45 pm
Aww Smo is lovely in real life :D
Postby jonyb4 on Fri Jul 23, 2010 9:48 pm
haha im sure he is nick, i wanna meet him :D
Postby Smo on Fri Jul 23, 2010 10:11 pm
hb69 :Not running the ms for ff?
SKINNY WHEELS :D
Says the skinny wheels man!
And hardly, not without a proper lambda sensor :lol: It did run well how I mapped it, but I'd rather know exactly how rich or lean things are :)
Smo
Postby jonyb4 on Sat Jul 24, 2010 12:10 am
ive never really thought about how rick/lean my engines are running, apart from my Si being standard engine wise atm (K&N exception) i dont see how you alter it
and i dont even know how you'd find out cheaply, only thing i can think of is either a diagnostic, or a widebend lambda and fuel to air ratio gauge :-?
Oh and the exhaust dropping ton of soot when you plant your foot haha
Popular Plus - 12/08/10 - Page 12 - Performance Ford Feature
Postby Smo on Thu Aug 12, 2010 11:50 pm
Yes, the last thing I ever thought would happen to my car would be a magazine feature...
... so yeah, it kinda happened :lol: Along with Dave and Ryan's Dirtbox :D
Only going to post a couple of photos and vids from the day as I don't want to take anything away from the fantastic write-up that Alex (Capri) did for us :)
Gary the cameraman!
Steve (bakewell001):
Alex, Dave and Ryan taking off for a lap:
A couple of videos of mine:
My second launch, just an external video:
And one from another run, just inside:
Buy the mag and read the feature :D Dave and Ryan deserve medals for what they did on that day!
Thanks once again to Alex and Performance Ford for organising it all, Gary for taking the mag photos and just being a genuinely nice bloke to chat to, especially about photography(!) and cheers Steve for coming along and also taking photos and filming some videos :D
Also went to Ford Fair on Sunday, did a few 0-60s... Not too good on the day really, car felt quite sluggish! Managed a 6.96 in the end, but I know it can do it quicker than that. It's probably down to how warm it was at the time though :( Really didn't like how they were doing the 0-60s this year either... Stupid place to have them!
Quick clip thanks to JamieFRST :D Hope you don't mine me using it!
Smo
Re: Popular Plus - 12/08/10 - Page 12 - Performance Ford Feature
Postby ~nomad~ on Fri Aug 13, 2010 1:19 am
defo more to come mate, both cars can defo go quicker. We aim to beat your 0-60 at trax lol
~nomad~
Your car: Breadvan
Postby jonyb4 on Fri Aug 13, 2010 1:24 am
congratz mate, looks really good int he runs and videos, pulling strong mate :D
id love my 1.8 close to this one day
Postby MB7201 on Fri Aug 13, 2010 2:27 pm
Well done both of you on the feature :D :aviator:
MB7201
Your car: Fiesta lx
Postby Smo on Fri Aug 13, 2010 6:50 pm
MB7201 :Well done both of you on the feature :D :aviator:
Cheers! :D
Smo
Postby hb69 on Fri Aug 13, 2010 7:47 pm
Well done on the feature guys. Nice to see some sleepers getting the attention :aviator:
hb69
Postby Ratspeed on Fri Aug 13, 2010 7:50 pm
Good job, whens the mag out?
Ratspeed
Postby jonyb4 on Fri Aug 13, 2010 8:00 pm
gratz on the features guys
like henry said good to see sleepers get reckonition
Postby hb69 on Fri Aug 13, 2010 8:24 pm
Ratspeed :Good job, whens the mag out?
In the shops now
hb69
Re: Popular Plus - 01/10/10 - Page 12 - Wideband Controller
Postby Smo on Fri Oct 01, 2010 1:33 am
Not a lot has happened recently... MOT on Monday which it passed and now I need to finally decide what to do with it :lol:
Whatever happens, though, I needed one of these:
(Bad pic, I know...)
Which will be connected to one of these:
And as of tonight, is currently mounted like this:
So yes, that's an AEM wideband controller and MegaSquirt (Ver 3 PCB/MS-I). The MegaSquirt I've had now for about a year (having ordered it over two and a half years ago! Long story...), and was running it when I first got it. I mapped it using the standard (narrowband) lambda sensor, with pretty good results, however there wasn't much point running it permanently until I got myself a reasonably decent wideband lambda sensor and controller. I was going to get an Innovate LC-1, but it has very mixed reviews, and I personally know people who have had issues with it, so I decided on one that seems to have very good reviews of reliability, and doesn't need free-air calibrating all the time. The Innovate LC-1 has more funky features, proper datalogging capabilities and is supposedly more accurate and faster, however for what I want, this AEM will do the job.
As you can see in the photo, I've mounted the gauge in the lower part of the centre console. I didn't want to cut any of the dash up, and I was considering using an old clock to mount the gauge (and using a MK4 Escort roof clock to replace it), but for quickness, I bought a DIN-sized radio blanking plate off eBay for not very much, cut a 52mm hole, and mounted the gauge in it. I think it looks worse in the photos than it really is, plus the dust and dirt don't help :bonkers: The worst thing is how bulky the bezel is, but unfortunately there's not a lot I can do about that. It does overlap the top and bottom edges of the blanking plate slightly, but it's not that noticeable.
I've got to wire it up still, but I wanted to know where I was putting it exactly first :lol:
Wiring will be pretty easy - All that's required is a ground, a +12v feed, and the feed to lambda input for the ECU. I'm going to use an old lambda plug and wiring to connect the gauge so that I don't need to cut into my engine loom - this will provide the ground, +12v feed and lambda input that I need. The gauge comes with two long cables, one for what I've just mentioned (plus also a wire for very basic hyperterminal datalogging), and one for the wideband lambda sensor itself. The hardest part will be deciding where I want to route everything in my messy engine bay :lol:
The gauge/controller can be switched between 0-5v linear, 0-1v non-linear, 0-1v linear and 1-2v linear calibration. To test the gauge, I'll try it on my current ECU with the 0-1v non-linear setting, and then once the MegaSquirt is connected back up (takes 30 seconds because I have an EEC-IV adaptor board), I'll be mapping and using the controller on the 0-5v setting, as this will allow me to most accurately do my mapping.
That's all for now :) I'll try and get it wired up tomorrow evening if I have a free half hour!
Smo
Postby Rhinopower on Fri Oct 01, 2010 7:22 am
baxtered. Your back ahead of us now on that side of things. We have 2 bottles of gas now though.
Rhinopower
Your car: Volvo FH330
Postby bakewell001 on Fri Oct 01, 2010 9:16 am
Awesome - Finally the ball is rolling again :D
bakewell001
Postby jonyb4 on Fri Oct 01, 2010 9:35 am
jesus this is heavy stuff, i lost you after wiring the lambda to the ecu, i know that bit thanks to the mk4 conversion :P
noobish i know, but whats the main benefits of megasquirt and that of the wideband? :oooh:
Postby bakewell001 on Fri Oct 01, 2010 12:10 pm
jonyb4 :jesus this is heavy stuff, i lost you after wiring the lambda to the ecu, i know that bit thanks to the mk4 conversion :P
Megasquirt is basically a better form of engine management. Your standard management is set to give you as much economy as possible whilst meeting emissions laws etc.
The aftermarket management will enable Simon to get the most out of the engine, and the wideband sensor will enable him to be able to map more accurately using Air/Fuel ratio, within the limits of the engine so it doesn't run rich/lean at any point.
I think! :lol:
bakewell001
Postby ~nomad~ on Fri Oct 01, 2010 12:42 pm
how much was the AEM mate? Will be needing a couple I reckon
~nomad~
Your car: Breadvan
Postby jimmyesh on Sat Oct 02, 2010 8:53 pm
Nice, can't beat a bit of wideband action :Q
jimmyesh
Your car: Yes
Postby Smo on Mon Oct 04, 2010 11:48 pm
Still not got it wired in yet, not had a chance with how the weather's been :(
It may have to wait, though, as I'll be taking things apart again soon :lol:
Smo
Postby jonyb4 on Mon Oct 04, 2010 11:59 pm
ive never seen your run around simon :(
Postby Smo on Tue Oct 05, 2010 12:18 am
You're not missing much :lol:
Smo
Postby jonyb4 on Tue Oct 05, 2010 7:39 am
Lol bog standard is she? :)
Postby Rhinopower on Tue Oct 05, 2010 8:01 am
Simon, our MS3/V1 is on its way now, any chance of a copy of your map so far to get us started with? :P
Rhinopower
