power cable1 amp
power cable1 amp
Postby garry_noble on Fri Jan 26, 2007 7:37 pm
fitting and amp into my fiesta si 1995
im just wondering can any of you give me any tips on where to run the power cable for my amp into my car
thanks
also how should i seal hole ect where can i buy plugs
thanks
garry
garry_noble
Postby Tweek on Fri Jan 26, 2007 10:06 pm
I couldn't get mine down the ECU hole so the way I did it was from the battery, across the back of the engine bay and down through the big rubber grommet in the back-left corner of the engine bay under the scuttle pannel, since it's rubber just pierce it, push the cable through and it'll return to shape sealing it.
After that unclip the kicker trim pannels one by one and feed the cable underneath it out of sight, hardest part is the seatbelt pillar area, once you've gone all the way down that, go under the back bench and into the boot, assuming you're putting the amp there anyway :)
Your car: VW Golf GTD
Postby garry_noble on Fri Jan 26, 2007 11:50 pm
hi is the rubber grommet got any other wires feeding through it
thanks
garry
also wats scuttle panel and where are the clips
thanks again
garry_noble
Postby xiphon on Sat Jan 27, 2007 2:00 am
garry_noble :hi is the rubber grommet got any other wires feeding through it
thanks
garry
thanks again
If I remember, I'll take a photo in the morning of how I have done it.
I wired up my amp last week (came with no instructions!).
Runs from the battery, through the large rubber boot where the ECU cables run down (I pierced a little hole on the underside), down past the ECU, and along behind the plastic trim.
Xiphon
Do not underestimate the power of a 1.3 - It's low enough already :-P
xiphon
Postby Tweek on Sat Jan 27, 2007 4:15 am
Scuttle Pannel - the bit under the windscreen with all the slots in and where the wiper arms end.
Clips: in the kicker pannels you'll see a few round "buttons" in them, you'll need a very small flat screwdriver to carefully prise them out.
Rubber grommet is where all your wires from inside connect to the engine, ie lights. If you look down behind the water expansion tank you'll see a big black rubber circle with chunky wires running into it :)
