Power lead for new amplifier installation problems?! : Insurance | Fiesta Forums
Postby succulentc on Sun Oct 15, 2006 3:27 pm
easy everyone,
Just installing sub/amp/6x9s in my mk4 fezzie, just cant figure out the best way to feed my power lead for the amp from the battery in the engine bay, to the intereior of the car??
any help much appreciated!
-C
succulentc
Postby :: blade :: on Mon Oct 16, 2006 12:28 am
all you do is drill a hole from the bulkhead in the engine bay, make sure you drill it so its somewhere behind the dash, i can get pics of mine but its on a mk3 no 4, and i see your from crewe, im not too far from there ;)
:: blade ::
:: blade ::
Postby Guy Mk4 on Mon Oct 16, 2006 3:46 pm
Dont need to drill anywhere in the bulkhead at all.
On the MK 4 there is a large rubber grommit behind the firewall, which with a bit of cutting will gladly take a power cable.
This comes out on the passenger side of the car, you need to take all the plastics on the left side off though, and the power cable will come into the cabin just behind the glove box on the passenger side.
Battery to firewall (Stanley knife off the corner, and feed the wire under the rubber seal.
Grommit for wire to go through.
Like it was meant to be there :D
Guy Mk4
Postby :: blade :: on Mon Oct 16, 2006 5:12 pm
ahhh, thats ok then, atleast theres pics of the mk4 with it done as i did say i did it on my mk3 fez, and i had to drill,
:: blade ::
:: blade ::
Postby lucasdemoley on Mon Oct 16, 2006 5:28 pm
ITS ON THE DRIVERS SIDE ON THE MK3. Go cutting throughthe passanger side and thats where your ecu is (or atlest on most models) and that could get interesting.
lucasdemoley
Postby Guy Mk4 on Mon Oct 16, 2006 6:19 pm
Well it's mine, and I'm glad I took them, cus it's a question that bizarely gets asked, but noone ever seems to have a clear answer. Just makes it easier than trying to explain "Cut here, feed wire here, stick it through this".
Guy Mk4
Postby succulentc on Mon Oct 16, 2006 9:11 pm
Thanks everyone for the replys, especially Guy MK4, the pics are a great help!!
Just one qu. Guy:
What d'ya mean by "you need to take all the plastics on the left side off" do you mean the panel the white arrows point to on PIC: A. below? If this is the case, its looks pretty easy, just 5 or 6 screws i counted, is it that easy??
Also i think i could spot the rubber seal from the inside when looking up from the floor behind the glove box - located as if it were the behind the top left of the glove box?? I snapped it in PIC: B. Am i right? i presume this'll need another small hole in like the grommit in the engine bay on your pic.
Cheers!!
succulentc
Postby Guy Mk4 on Mon Oct 16, 2006 10:28 pm
You got it in one :)
Those are the trims to take off.
Easiest way to check you have the right grommit is to get a mate to wiggle the wire going though it. If it moves you got the right one. Quick incision with a Stanley and you're away.
There is enough room to run your power cable under those plastic trims to your boot too :D
HTH.
Guy Mk4
Postby succulentc on Mon Oct 16, 2006 11:07 pm
much appreciated!
thats mint, i'll get that all finished 2moro now, your a life saver mate!
cheers again
-C
succulentc
Postby lucasdemoley on Mon Oct 16, 2006 11:56 pm
IF YOU HAVE A PLASTIC COVER on the passenger side, all is well. But if something else is there, this is the ecu and you must go through the other side. WHen i did mine, i simply pushed it out, and you could reach without having to remove the trim, although i guess to run it down the car under the carpet you have to remove the trim.
lucasdemoley
Postby succulentc on Tue Oct 17, 2006 9:32 pm
Hello again,
one last problem! i promise this is the last!
Just bin trying to get the plastic trim off down the left side interior, but cant get to the screws?!?!
i presume they're behind the plastic tops below? but i cant even get these off without F**king them up and damaging them?
anyone?
succulentc
Postby Priezti on Tue Oct 17, 2006 9:36 pm
Guy Mk4 :Dont need to drill anywhere in the bulkhead at all.
your engine bay is scary clean, when you actually going to drive it :) lol
Priezti
Postby Guy Mk4 on Wed Oct 18, 2006 12:38 am
I think you'll find dirt just by the hinges :P
Dont look that clean right now, that was the day after a good clean :)
As for the caps, they are more like plugs. If you can find a really thin screwdriver (Like one of the tiny ones you get in Christmas crackers) you can prize them out. You may lose one or two of the legs of the plugs, but they push right back in. Plus they are pence from Ford :)
Guy Mk4
Postby lucasdemoley on Wed Oct 18, 2006 12:57 am
Guy Mk4 :Well it's mine, and I'm glad I took them, cus it's a question that bizarely gets asked, but noone ever seems to have a clear answer. Just makes it easier than trying to explain "Cut here, feed wire here, stick it through this".
IM not doing an attack to you putting the pics up etc, but its a mk4, not a mk3. You have that rubber gromet thing on the passanger side, its on the drivers side on the mk3. On the mk3, you either have a plastic pannel that is fine to drill through and pass a power cable through, or you have a rubber cover, that has your ecu behind it, and that wont be fun to drill through.
YOu may have to remove the bar that your seatbelt ataches to by the door to get that bit of trim off as its quite difficult to move the plastic with it in the way.
lucasdemoley
Postby Guy Mk4 on Wed Oct 18, 2006 11:24 am
lucasdemoley :
succulentc :easy everyone,
That clears that issue up. The guy is installing it in a Mk 4 :P
Guy Mk4
