Ppanasonic RDP212N
5 posts • Page 1 of 1
Ppanasonic RDP212N
i was just wandering if anybody knows whether you can connect a amp to this stereo?
- rebel
if you look at the back you should see two or 4 holes at the back, depending on how many pre-outs it has, there whould be one red and one white, where the amp wires go and then there is an RCA lead which you need to connect, someone will tel you more tho,
have you got any pictures of the back of it?
hope this helps,
:: blade ::
hope this helps,
:: blade ::
- :: blade ::
:: blade :: :if you look at the back you should see two or 4 holes at the back, depending on how many pre-outs it has, there whould be one red and one white, where the amp wires go and then there is an RCA lead which you need to connect, someone will tel you more tho,
hope this helps,
:: blade ::
it does have the red and white holes
- rebel
