Price for a Turbo
Postby Grousey on Tue Jul 31, 2001 10:17 pm
Where's the best place to get a FRST T2 Turbo and how much would you be likely to pay?
Alternatively does anyone have 1 for sale second hand?
Grousey
Postby MOONDUST FRST on Sat Aug 11, 2001 12:20 pm
Got a T2 for sale £100 but the actuator is broke on it.
MOONDUST FRST
Postby Nixxy on Sat Aug 11, 2001 2:37 pm
Id be interested in that as mine has just started to smoke bad. :sad:
Nixxy
Postby kirk sear on Tue Aug 14, 2001 2:45 pm
try checking the oil pipe that goes to the turbo as they get bloked.r u running more than standard to. :???: :???:
kirk sear
Postby Nixxy on Tue Aug 14, 2001 3:43 pm
Im running 15psi on standard,and i need a new boost control valve cos mine has broke.
Could that pipe be the cause of all that ducking smoke thats there on idle and when i brake?????
Nixxy
Postby snake on Tue Aug 14, 2001 5:43 pm
If it smokes when u brake look inside the brake servo and check for brake fluid inside, also check the level. U could be smoking brake fluid :eek:
snake
Trainee Burger Flipper
Your car: ford
Postby Nixxy on Wed Aug 15, 2001 9:36 am
So i need 2 check the oil pipe and brake fluid.
Nixxy
Postby ande on Thu Aug 16, 2001 7:22 pm
If it is your turbo then Motorsport Developments do a repair kit for £70. It was a piece of pi-ss to repair it as well. As long as you do nothing to the shaft and mark the turbine that comes off the end, you won`t have to worry about getting it re-balanced.
Hope I have helped.
ande
Postby Nixxy on Fri Aug 17, 2001 8:27 am
£70 and i can start having fun again. I will give them a ring, cheers matey.
Nixxy
