Pro2call's supercharged RS1800 zetec
33 posts • Page 1 of 1
Here is an topic of my fiesta mk3 rs1800
I have this car now for about 1.5 years so i wont upload the complete story at once.
OK... here we go.
I had an ford escort 1.3 hcs where the engine almost broke down so she had to go.
Searching on the internet for an rs1800 I found 1 about 200 kilometers away which had an ruined head gasket.
After a couple of call’s and some pictures I went to this guy to see the car. It looked nice in a dark shed. LOL so I buyed the car and took it with me on a trailer.
(some pictures of the car at the seller)
So when I was at home I pulled the engine apart. Not much pictures left
There were no service history so I ordered the complete service kit for the zetec.
Yes again pictures
[/color]
After the parts arrived I started to rebuiled the engine yes on the street in the rain :banana:…
OK... here we go.
Yes again pictures
[/color]
- pro2call
Re: Pro2call's supercharged RS1800 zetec
So when the engine worked again and drove a week I noticed my tires are totally ruined.
So on the ramp to look what’s wrong. Well here is the list
2 wheel bearings almost gone
1 wheel hub
2 shock absorbers worn
1 wishbone gone
Replacing the hub and a bearing:
So after we fixed this problems I noticed some wet feet in the car
So lets get discovering where the problems are…..so out came the dash and al the other parts (what was she quick)
next update soon.....
1 wheel hub
1 wishbone gone
- pro2call
So here is an update this time I post it until today
After an while I was bored with the 130 Bhp…. So out came the exhaust and in came an complete Ashley system.
This was nice.. but to get all the performance out of the exhaust I needed an remap af the ecu. But I wanted later on more power. so I got an DTA System the S40
And after it was installed in the car I needed to go to the dyno…
So 158 Bhp and 190Nm torque.
After the hunger of more power keeps existing
So lets eBay for more stuff…. No no turbo but an supercharger something different ..
After a while the postman was here standing with an huge package…
Let’s check the inner parts of the unit
Everything looks good so lets build some bracket’s
And fit it in the car
http://www.youtube.com/watch?v=E9Lz6LGDrgk
So with the performance in the eye (275 bhp and 400Nm torque) I need an other gearbox. And ford is just like lego. So I bought an Focus 2002 ST170 6speed Gearbox with axels.
So lets build the biggest part of the complete setup
My mate took this picture of me…..
So far this update this week more stripping the car and starting welding.
- pro2call
Here is another update
Well we started with braking apart the whole car...
Here started my mate doing some welding..
mean while i started hanging in an the engine with the 6Speed
Welding the gearbox mountings
My mate finished today with the upper gearbox mounting...
The blackbox you see is an Chargecooler from an 04 Focus RS Turbo
well.. more progress isn\'t here for so far
- pro2call
This week started my mate with building an custom intake for the Zetec which going to house 8 injectors (2 small 1’s per cylinder for better mapping).
For the rest not so much to update the windscreen came out yesterday, the door’s came of, the skirt’s came of by angle grinder , and we modified the engine which came out for the Getrag MT285 gear box for the rest we were fixing my Fiesta2 for MOT…
We also discovert that we have lots of bodywork to do
- pro2call
This time no big update….. srry about that
We modified the engine to accept the starter motor. And fixed an original flywheel, clutch and pressure plate.
We also made the sub frame fit the box…
We also build some kind of ramp for the shifter. So the shifter is closer and under an angle. Much easier to shift. (Yes we also mounted the shift cable’s)
And we made an plate for the charge cooler to stand on…. Further we where busy with removing the bitumen
- pro2call
now some one has been busy i like this thread very much and someone doing it different
- frostie
Very nice
You might want to send a moderator a PM to get this moved to the members gallery. More people will see this there.
- Chris 2i
great project mate
ive been thinking of a supercharger for my car
- jonboisescort
Car: 1994 Ford Fiesta
Let's start this update with an overview of the interior...
last week my mate welded and welded and welded All for strengthen the body. The rust will be done when it is in the rotary spit.
Some pictures of all the welding...
All the strengthen welding is almost done.
After this my mate backed up to weld some intjector hole's on the intake...
70mm Throttle body..
After this we decided to open up the €2500 piece of equipment... the charge cooler to determine the angel of the intake..
And here we are test fitting and cleaning the Ford escort mk5 rs2000 rear diskbrake's. I need to place a couple of ford ka 2000 spacerplate's wich are made to fit.
I'm having holyday for this and the next week so i hope do do alot...
- pro2call
great project...i love the way nothing seems to be a problem.. ..keep up the good work and keep the updates coming.. .
- FRSJON
fantastic project mate, love it, keep us updated
- SamT
looking really good mate, keep up the good work, wish i had as much motivation and confidence as you. will be a giggle to drive without the lag issure. i bet you will be chassing some big boys in your rs
rebuilding new rs1800 engine with omex and jenvy throttle bodies. bring on the trumpets!!
- rs1800dom
- Your car: Mondeo ST tdci Estate/RS1800
love the car can't wait to see it running
- HCS PIMP
The last 2 weeks whe have done alot
almost completed the strength welding, put the car in the rotary spit, Replaced some panel's and repaired some rust, and already sprayed some stone chip coating and cleaned the shed out
Here are some pictures of the almost completed the strength welding:
Here are some pictures of putting the car in the rotary spit:
Dicovered some more rust and early repairs........
Replacing some panel's:
Repairing rust :
The old innerwing
Sprayed some stone chip coating of course everything first in the primer:
Repairing rust :
The old innerwing
- pro2call
wow thats awesome matey, i like what your doing good workmanship! i can only dream to do what your doing lol
- Scott69
- pro2call
lots of good work youve been doing.
what is the super charger off i notcied its got TRD on it is that toyota racing developments?
old fords never die...............they just get faster!!!!!
- white diamond
What a project! Its slowly getting there!! Will be good to see it when its all finished.. keep us updated while you go!
- - Danny Boy -
- Your car: Fiesta Si 2.0
white diamond :lots of good work youve been doing.
Hi Yeah it's an Toyota racing development Charger. it's from an 2.4 scion 04.
- pro2call
pro2call :white diamond :lots of good work youve been doing.
ahhright. what sort out of power will it be putting out once its complete?
- white diamond
he is aiming for 275 and 400 Nm of torque
nice work mate, akways been a fan of supercharger whine
- Ruishy1
i'm liking this alot good work mate keep it up, very different
love the fabrication work spot on
- Pastieman
- Your car: Mk3 Fiesta Rs Turbo
- pro2call
After an very long time no update... here is 1
because there was summer here in the netherlands we decided to do
nothing to the car so we can relax in the sun Catching some ray's
Last weeks we have managed to get the roll cage in and some panelwork.
I also bought an sandblasting gun so i can sandblast all the rust gone.
Also we have all the parts from the sub-frame welded and prepared for
powder coating... and last but not least i discovered today more rust
My new sand blasting gun
Some of the new parts... Mocal 16 row oil cooler, Powerflex bushings, OMP tow rings, Forge dumpvalve Bullet Fuel filter and some parts for the rollcage
The subframe/rear axle to get powerder coated
Fitting made for the OMP tow ring
The rollcage fitted
And the extra rust I found today its on the innerwing on the left front side...
The rollcage fitted
- pro2call
blinding work cant wait to see wh\at this baby goes like
- JoeyZetecT
- pro2call
- pro2call
cellent work mate.
very nice project
very nice project
- Ruishy1
That is sooooo coool, ive just nearly lost my job on several occasions reading this....but well worth it, youve put in some serious torch time in this build bet your loving that welder now ......
If at first you dont succeed......buy another ford......
Im really a very good driver.....
- GTIgerald
Nice work mate Love the beer crate axel stands!
Is that how you keep your mate busy welding in there? By keeping him well stocked with booze?
Keep up the good work
- RS Joe
- Pastieman
bloody hell alot going on, nice work mate
