problem with my fiesta rs turbo until its warm?
31 posts • Page 1 of 1
right i start it up when its cold and it splutters like its running on 3 cylinders for the first 5 minutes or so, after that the problem clears and runs / drives perfect. any ideas what this could be? HT leads are new, sparks are new, temp sender on the rear of the inlet is new!
possible coilpack problem but as said its only when cold, after 5 minutes it idles fine! map sensor?
- rob pace
Re: problem with my fiesta rs turbo until its warm?
try the coolant temp sensor
- FRSJON
FRSJON :try the coolant temp sensor
on the rear of the inlet? thats new!
- rob pace
Could be a leaky injector
Check the plugs and see if one is dis coloured more
- gup
gup :Could be a leaky injector
there all a nice brown colour, car will start then cut out a couple of times when cold, once running its spluttery for 5 mins then runs fine!
- rob pace
had this exact same problem with a 51 plate focus 1.6 zetec
leaking injector kept weeping onto the piston
then when u start it - it delayed starting straight away and mis fired until fuel cleared.
do a drip test on all for injectors with ignition on
- knuckles
- Your car: Fiesta Rs turbo
knuckles :gup :Could be a leaky injector
how do i do a drip test clarke? heard of it but not entirely sure dude
- rob pace
Take the fuel rail off complete with all
injectors fitted and everything plugged in , get 4 clear cups and place them under Injectors now turn on ignition so the pump builds up some back pressure in the rail and then just wait for a while
A leaking injector will obviously be visible now in your cups mate and jobs a Goodun , please don't do it whilst car is hot aswell or you may end up with a frst BBQ
And see you got same response on pf as here then lol
Anyway hope it helps mate , its usually common especially with diesels for a leaky injector to cause a misfire on startup and/or smoke a little
- Boostjunky
- Your car: Ford
Boostjunky :Take the fuel rail off complete with all
thanks dude!!
- rob pace
Agree to the drip test.I would also suggest to do an ultrasonic cleaning,especially if you haven't done it before.I had some problems with idleing,and did a cleaning.Usually they measure the injected volume in different RPM's from each injector,in an emulating machine,outside the car,if there is a deviation from what it should inject at the first place,dismantle them,replace prefilters,o-rings,ultasonic clean them and reassemble them with new parts.It fixed my idle and also helped a bit with consumption,especially on part throttle,I noticed it from the A/F gauge I have installed.I had to set it up again after cleaning.Regarding coolant sensor,ECU reads only the inlet manifold sensor,this is from what regulates mixture.The other coolant sensor,which is in front beside the exhaust manifold,is just for the gauge,it is not connected to anything else.
My Ford Escort ride
My Ford Escort ride
- georgiocat
thanks guys, will do leak test last! tried a tps today and another coilpack and the problem persists, got a spare map sensor and edi4 unit or whatever thee called somewhere to try tomorrow
- rob pace
seemed to be the coilpack, bought one off ebay and it was worse, bought a new nkg one and seems ok. but prefer a new genuine ford one if anyone has one?
- rob pace
Why would you want a gen ford one ( albeit second hand )if a non standard one does a better job??
- RS EDDIE
I got one rob if you want genuine like Ed said though why does it have to be ford???
- rsturbonutter
- Your car: Fiesta RS turbo
There was piss all wrong with that coil pack tried tested worked i refunded you and you refused to send tge coil back sick of getting migged by people
- fezzRS
- Your car: run about
And why tge hell do u want a ford coil pack when they are twenty years old you just brought a new one and its solved your problem yet your still messing
- fezzRS
fezzRS :There was piss all wrong with that coil pack tried tested worked i refunded you and you refused to send tge coil back sick of getting migged by people
your use of English grammar is terrible, it was worse when running with your coil which was so piss poorly wrapped in the first place. Yes i did have a moan about sending it back for the £10 or whatever i paid, it would cost me about £3-4 in petrol to get to the PO and about £6 to send the bloody thing back as it weighs a lot.
come and get the coil when you want the UK spec lights, but you have pissed me about more times than i have had hot dinners about collecting them! lastly go through the ebay messages, at what point did i refuse to send it back?? all i moaned about is that it would cost me more to get it back to you and i never heard a reply after that?
- rob pace
Bic™ Fight!!!!
- RS EDDIE
Is "Getting Migged" by people, when someone is attacked by a welder??
- RS EDDIE
We need a like button
- rsturbonutter
Ye bruv mugged is getting welded by somebody and my grammer is bad is it lmfao i can spell and i proved it that coil pack works
- fezzRS
Ye man we need a like button hit the buzzer like hah
- fezzRS
Fuk all wrong with that coil tried tested was working before i sokd it
- fezzRS
^^^^ "Migged"!!!
- RS EDDIE
Still having issues then rob told you it was not tge coil pack
- fezzRS
Migged mugged nagged plucked what ever u wanna call it Eddie you carry on
- fezzRS
Ok......i will.....you did state "Migged" lol lol
- RS EDDIE
Did you sort this problem out? As frsjon said try coolant temp sensor more than likely that (on top of the thermostat)
- ZetecsTurbo
- Your car: Mk5 Zetec s
ZetecsTurbo :Did you sort this problem out? As frsjon said try coolant temp sensor more than likely that (on top of the thermostat)
yes its sorted.
- rob pace
What was it?
- ZetecsTurbo
Just got mine out today and it's started doing that exact problem, so I will give a new coil pack a whirl, was just about to buy some new leads but will try that first
- GeoffeRS
- Your car: Fiesta XR2i 2.0 and Fiesta RST
