problems after fitting new suspension
16 posts • Page 1 of 1
i fitted newish suspension (brought off ebay, bloke said they had covered 500 miles and been sitting in his garage for a year, and to be fair they looked clean, no rust etc) but have had knocking noises coming from the front two ever since (back ones are ok) and its doing my head in! ive fitted new rubber doughnuts that go on the top of the struts but the noises are still there. if i rock the front of the car and put my hand on the struts i can hear them knocking and rubbing on the doughnuts. firstly, are you meant to grease the doughnuts up to stop the rubbing? and secondly, could the shocks be knackered? i took the original bump stops off and replaced them with spax ones, would that of done anything to cause this?
please help me!
please help me!
- dee_RS_2ltr
Wrong kit for the car ? shocks leaked dry ? could be a number of factors.
You need to get your car inspected and find out.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Did you 'prime’ them before fitting them? If they have been stored for a while, most likely on their side, then the shocks will need to be fully compressed and released a few times for the gas/liquid inside to disperse properly. I’m not 100% sure if this will solve your problem but if may be a factor to consider.
- Sphinx
oh right, how do you prime them? it seems its only the front two that are the problem, the back ones are fine. when i got them they were just in a box they didnt look greased up or anything so i reckon they're dry. how can i get round that problem? could a bit of WD40 do the trick?
- dee_RS_2ltr
To prime them you have to take the spring off and compress the shock fully then let it expand fully a few times. If there are any bubbles in there you will hear them at 1st and then they should dissapear. hth
- Sphinx
i had that [ERRR] my old spax it was the spring not sitting right kept moving in the lower cup 4 week and it works it way out
but that wot i think
- fizxr2i1649
If you've lowered your car then theres going to be extra stresses on the tug lower TCA's (A great design by Ford )
It could be that they were worn already and the lowering of the car will have slightly knocked the geometry out. Maybe worth replacing these, their cheap as chips or keeping ya old arms and putting PowerFlex bushes in there (or another aftermarket make)
Good Luck tho
Good Luck tho
- BillyCabrio
whats the TCA's? ive had both CV joints renewed the other day. ive had the springs off a few times now and checked that they're seated properly and they are so im gona check the engine mounts. then if that dont work im gona buy some new shocks. just thought, the back ones are fine, they have PI shocks and springs, the front however have PI shocks but fiesta center springs as i wanted the front lowered by 50mm and they were the only ones who made them. could that be the problem???? i hope it is!!
- dee_RS_2ltr
also i put new spax bump stops on but took the orginal ones off, could that do anything? i jacked it up yesterday and sprayed WD40 on the bumpstops and on the rods and it seems to do the trick for about 10-15 miles then it starts again
- dee_RS_2ltr
TCA's as in the lower Track Control Arms?
Their trianglular in shape, with bushs made of plasticine.
- BillyCabrio
oh those, i checked those and they look fine, no splits in the rubber or anything, one is only a year old, the other is about 2 i think.
- dee_RS_2ltr
- BillyCabrio
i have the same problems....from what i have been told, the tca's (wishbones) will have to be re setup, mine was doing it before i lowered it... will let u know during the week, as mine sre being replaced and setup on mon night.
- rob c
