Project Blackoak - Selling or Breaking :(
118 posts • Page 1 of 4 • 1, 2, 3, 4
It's here at last my car is running:
2.0 US Spec Zetec-E
Decomperssion plate and 2 Headgaskets
T3 Turbo (stage 2)
Piper Cams
Focus Inlet Manifold
Mazda Injectors
Escort RS Charge Carrier
Stainless T3 System
Airtec Intercooler
Radtec FRST Alloy Radiator
Blackoak ECU (mk3 mondeo)
ST170 Brakes Front and Rear
Zetec-S Rear Beam
Mk5 Escort Servo and Master Cylinder
16" Mondy Si wheels
Power Steering added from a Si
mk5 Dash - mk4 heater
MK5 Fiesta Black leather seats and door cards and one off front Recaros.
Mk3 Mondeo Clocks
2.0 US Spec Zetec-E
T3 Turbo (stage 2)
Piper Cams
Mazda Injectors
Stainless T3 System
Airtec Intercooler
Zetec-S Rear Beam
16" Mondy Si wheels
Mk3 Mondeo Clocks
- allinking
Ahh right! I wondered if you were the buyer of my my loom/ECU. I don't know anything about the ST management system. What is the benefit to using it? Are you running 2 O2 sensors etc then?
allinking :The benefits of using is that if you brother works in engine callibration it becomes a fully mapable ECU so has been set to use only one HEGO. Lots more info to come once its all run in
Interesting, keep us updated!
- RS rob
what was the fit of the ashley one like?
6 Point Safety Devices Cage.
- purple_fiesta
Just a bit of an update needed to change my clutch but at the same time though why not fit all the bits I have bought for the car so out comes the engine and box and every thing else for a weekend to do list:
mk5 Dash and Heater
Clutch
Cam Belt and Water Pump
Power Steering
Mk3 Modeo Clocks (maybe see if the fit the dash first)
Would also like to do the Zetes S rear beam and Escort master cylinder but have yet to purchase.
If any one wants pics and details of any of the jobs let me know and I will post some of the many pics I've taken to remind me how it goes back
This is what I got done last night
I also have the MK4 heater in and the hole cut next up change the rack and colum for the powersteering [/img]
mk5 Dash and Heater
Clutch
Power Steering
- allinking
Right got the dash in and most the wiring done also did a small guide to powersteering for a friend so thought i would share.
Dash Almost fitted.
Power Steering Quck Guidehttp://www.xms-uk.com/power.doc
Dash Almost fitted.
- allinking
- chumkila
- Dirty Post Whore!
Thanks just a quick update the car is now going back together after the fitting of power steering, clutch, water pump and cam belt along with the mk5 dash and hope fully w the mk3 mondeo cluster which should be here tommorow hope the ford cad dimensions are right and i can make it fit!!
- allinking
- Xr_Dub
- chris-fiesta
Looking good!
- TomRS1800
- Jay
Car: 1992 Ford Fiesta RS 1800
They are just floating ATM but they do sit central just got to fabricate 2 brackets 2 hold them in position.
The car is running the mondeo blackoak ecu so is straight forward.
- allinking
Very nice - Shame ford never put that dash and clocks in from the start
Cruisers dont die they just keep cruisin
- CrAzY kAyLL
dash looks awesome. have a word with Project on here about you sender, i believe he has fixed that prob in his
- ~nomad~
- Your car: Breadvan
What's the crack with a US spec Zetec?
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Love those Mondeo clocks.
- Ollybee
