Re: Diary of "JPH" 2.1 ZT (shell is painted 9/7/10)
llama fluffy cloths
Re: Diary of "JPH" 2.1 ZT (the rebuild 19/7/10)
time to start rebuilding,
looking at the fiesta turbo steering rack one of the tie rods, seemed very loose
so bought a new kit for both sides,
old
new
while changing them i scotched the main body and gave it a few coats of satin matt black
fitted in the bay, happy with the finish
last weekend i went to see my engine builder, area six / ian howell
the main reason was to have my fuel pump uprated
so ian has installed a pump from an evo, rated between 450-500bhp (not that i'll ever be that powerfull)
new pump on the left, to be fitted to the standard 1600 zetec fuel sender/pump unit on the right
brought my skimmed flywheel home, as it wont be used on the harvey gibbs engine dyno
got myself a new fuel pressure reg from ian aswell
also my engine was there with the old cam cover on
aswell as a new sump with oil return on the back for the planned oil breather setup
my new t38
old
new
my new t38
- RS rob
i just wet myself with glee WOOOWW
- HCS PIMP
thanks................ i think
- RS rob
what sort of power are you aiming for ?
- crazycage
has that oil return been plumbed in below the oil dipstick level ?
- knuckles
- Your car: Fiesta Rs turbo
cant wait to see it fitted i take it its going to harvey for running in and mapping ?
- FRSJON
crazycage :what sort of power are you aiming for ?
original plan was a genuine 300bhp
spec has changed quite a bit since
so looking forward to having results from the engine dyno
- RS rob
knuckles :has that oil return been plumbed in below the oil dipstick level ?
it's the oil return for the oil breather
I'll ask ian
- RS rob
FRSJON :cant wait to see it fitted i take it its going to harvey for running in and mapping ?
same here Jon, your bang on aswell
run in and mapped by Harvey
then with the engine back in the car
I can get the wiring loom done
- RS rob
RS rob :crazycage :what sort of power are you aiming for ?
cool mate ,i would expect over 400hp with that turbo
- crazycage
crazycage :RS rob :crazycage :what sort of power are you aiming for ?
hopefully wont be too long before we find out
- RS rob
looking good mate, that engine bay is looking so nice
ok thought it was time to catch up with the progress
to finish off the steering i bought some new track rod ends
also had to clean some the hubs where the powder coating is'nt supposed to be,
with a purple scotch wheel it was'nt too much of a problem
which allowed me to fit the coilovers to the hubs
and on the car
been buying some gauges as its the perfect time to fit the sensors to the engine
the oil temp sensor is either to be fitted to the sump or sump plug
act sensor from R&B motorsport to help me keep an eye on the inlet temps
the new inlet manifold will be drilled and tapped to take the sensor for this
and on the car
- RS rob
Re: Diary of "JPH" 2.1 ZT (the rebuild 9/8/10)
looks good, sad to think that in a few years/ thousand miles most this area will be rusted up and stinking dirty
was you at Ford fair? didnt see the Zs
Stunning fella
Any idea on how much this is all costing or are you not counting
- Turboboy67
- Your car: 911GT3 RS
jonyb4 :looks good, sad to think that in a few years/ thousand miles most this area will be rusted up and stinking dirty
rusty and dirty? dont swear at me
the shell was in suprisingly good condition before i started,
the time spent on prep and not cheap materials used
it will be some time before its rusty
on another note, yeah i was at ford fair on the FT.com stand
- RS rob
Carbonboy67 :Stunning fella
thanks fella
not counting
- RS rob
Looks good , Rob. Can't believe you're ditching the superb PAS rack
Excursion :Looks good , Rob. Can't believe you're ditching the superb PAS rack
looking great as always rob great to meet you at last as well
- FRSJON
my old rack was leaking, pump a bit noisy then priced up a new rack at £700 odd from fords
as i've been buying everything new i priced the powersteering oil cooler up, had gone from £80 when i priced it previously to £350
that was the turning point for me,
my old 106 track car was non power steering and i found it great
- RS rob
FRSJON :looking great as always rob great to meet you at last as well
yeah same here mate,
thanks again
- RS rob
RS rob :my old rack was leaking, pump a bit noisy then priced up a new rack at £700 odd from fords
Reconditioned racks are fine, that price sounds like an outright purcahse price to me? Sandblasted & powder coated cooler is fine, or even one from another car
With all that power you have it seems like a step backward - with PAS you will grapple with the car less and be in more control. All the best handling cars in the world have HPAS, and PAS always stays on the more hardcore versions (M3 Competion, M3 CSL, GT2 RS, GT3 RS Etc.)
Excursion :RS rob :my old rack was leaking, pump a bit noisy then priced up a new rack at £700 odd from fords
yeah fair point,
but with the power steering gone it gives me more room for other toys
such as remote oil filter housing and cooler
- RS rob
had some bits to do to the heater box,
renewed the foam gasket
also as i have three gauges in the centre grill on the dash,
i'm blocking this up, so cut up an old numberplate to do the job
got myself a nice turbo oil feed pipe with extra pre-turbo filter
put the new rear engine mount on and put new bolts on where the front engine mount would be after cleaning the threads out first
how the engine bay is looking at the moment with the brake servo/master cylinder on
- RS rob
RS rob :knuckles :has that oil return been plumbed in below the oil dipstick level ?
I'll ask ian
the cvh oil breather return goes above the oil level on the block
ive got a feeling the air wont be able to go from the sump to the breather if its under the oil level .... ?
- knuckles
knuckles :the cvh oil breather return goes above the oil level on the block
Clark, it's better to return below oil surface level. A return placed within the crankcase area will suffer blow-back with a high boost engine.
Re: Diary of "JPH" 2.1 ZT (the rebuild 30/8/10)
Rob, I think it might've been you I mentioned the squeaky dash/vents to...I found the ever-annoying dash squeak in my Mk3 came from the point at which the outer corners of the central dash vents came into contact with the soundproofing up on the dash. They squeaked and fidgeted together once fixed to the dash. Once I notched out the soundproofing the squeaking left for good
heeman10 :Rob, I think it might've been you I mentioned the squeaky dash/vents to...I found the ever-annoying dash squeak in my Mk3 came from the point at which the outer corners of the central dash vents came into contact with the soundproofing up on the dash. They squeaked and fidgeted together once fixed to the dash. Once I notched out the soundproofing the squeaking left for good
i'm on the case james
i remember reading it on your project thread
- RS rob
Excursion :knuckles :the cvh oil breather return goes above the oil level on the block
a high power cvh still has a oil return from rocker cover to the block ?
- knuckles
knuckles :a high power cvh still has a oil return from rocker cover to the block ?
...which isn't as good as returning to the sump
fair enough
ive always been told having any returns to sump below oil level causes problems.
example: turbo oil return
- knuckles
knuckles :fair enough
That's a different case: returning liquid which is under pressure. If there is any resistance to the flow the oil backs up through the Turbo bearings and causes smoke.
The Oil breather drain is returning oil droplets by gravity, and in this case, it doesn't take much to force the droplets back up in to the breather pot.
f**k the bay is looking fresh, not even ford would have made it look this good, they rolled to many off the liones to put this much attention to one
top work mate, will be done to such a high standard through out by the time its done
