project "JPH" 2.1 ZT 358bhp-365ftlb : Member's Gallery - Page 24 | Fiesta Forums
Re: project "JPH" 2.1 ZT 358bhp-365ftlb
Postby RS rob on Sun Feb 13, 2011 7:37 pm
The view i've been looking forward to seeing, although it still has the old blue cam cover on which wont be blue!!
tried the inlet on to check out the space available
enough room for some piping there behind the master cylinder
the reason i want to modify the cam breather, very tight to the billet fuel rail
RS rob
Postby jonboisescort on Sun Feb 13, 2011 7:42 pm
:Q
awsome work mate :Q
jonboisescort
Car: 1994 Ford Fiesta
Postby jonyb4 on Sun Feb 13, 2011 7:46 pm
looks awesome mate, finally its got an engine again! :D
That's the bottle cap I have
Postby jayrs on Sun Feb 13, 2011 7:59 pm
:Q :Q
Postby FRSJON on Sun Feb 13, 2011 8:24 pm
looks great rob ! next time your at the car can you take me a pic of the engine through where the rad would be? as in the front of the engine .send it as a pm if you like .cheers :)
FRSJON
Postby RS rob on Mon Feb 14, 2011 8:50 am
FRSJON :looks great rob ! next time your at the car can you take me a pic of the engine through where the rad would be? as in the front of the engine .send it as a pm if you like .cheers :)
its in work with me jon, so every day
what are you trying to see??? or work out?
RS rob
Postby mrorange2 on Mon Feb 14, 2011 11:37 am
Looks awsome Rob great job :D :D
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby SiST on Mon Feb 14, 2011 6:37 pm
Inspirational work as usual - i love it!
SiST
Postby FRSJON on Mon Feb 14, 2011 6:37 pm
RS rob :
just being nosey :D just a pic of the ports,front engine mount/alternator bracket :)
FRSJON
Postby - Danny Boy - on Mon Feb 14, 2011 6:42 pm
Looks AWESOME Rob :D
- Danny Boy -
Your car: Fiesta Si 2.0
Postby danthehat on Mon Feb 28, 2011 1:43 pm
RS rob :hardly used puma gear selector which will complement the ib5 gearbox well for good shifting
Great job with this car mate. Been following your thread for a while now and its pretty amazing.
Just wondering with this gear lever swap you doing to fit the iB5, does the gear box and this selector just bolt straight on the MK3?
danthehat
Your car: Fiesta XR2i
Postby Excursion on Mon Feb 28, 2011 2:44 pm
danthehat :
http://www.mwstewart.co.uk/cars/pumalinkage/
Postby danthehat on Mon Feb 28, 2011 5:09 pm
Thanks mate. very helpful :D
danthehat
Postby RS rob on Thu Mar 17, 2011 9:46 pm
well some progress has been made,
currently my main car loom is now in the hands of excursion
as the plan was to remove unwanted cables from the loom, aswell as removing fords pats system
so that theres no complications later on in the build and i already have a good alarm/immobiliser system
also i've had paul cheshire down to discuss/measure the pectel engine loom,
he'll also be sorting the rest of the original engine bay loom with braid (lights etc)
as it looks a bit messy at the moment
i've put the exh manifold and turbo on to see how much room i'm left with..............
not alot
the main compressor housing would be mega close the radiator
and the down pipe would be mega close to the front lower crossmember
was going to change the manifold later on for a less restrictive tubular style once i'd got used to the power,
as this would let me use the full boost throughout the rev range
but as i want to keep the factory bonnet latch / dont want bonnet pins
so looking into different manifold
RS rob
Postby Max M4X WW on Thu Mar 17, 2011 10:18 pm
I found exactly the same last week with my 3" downpipe and wondering where the hell a rad is going to go :(
Postby jonyb4 on Thu Mar 17, 2011 10:27 pm
looking good, its gonna be tight in there
hopefully a different manifold design can help you out, are you not considering moving the rad forward as much as possible?
or does it conflict with the cross members and bonnet catch?
Postby knuckles on Thu Mar 17, 2011 11:44 pm
Max M4X WW :I found exactly the same last week with my 3" downpipe and wondering where the hell a rad is going to go :(
i have had to encounter this exact same issue when i went t3
moved rad and intercooler setup forward to clear actuator. Had to cut a section out of the front panel and a little more trimming on the front bumper for the fan clearance.
the next issue was making a modified bracket to attach the now relocated setup to the top of slam panel
was a pain tbh :(
knuckles
Your car: Fiesta Rs turbo
Postby RS rob on Fri Mar 18, 2011 9:45 pm
it does look a pain clark,
if i can help it, i dont want to be restricted when it comes to the rad
also still think of the grs intercooler as i like the design etc
but thinking of approaching graham about a single pass version
RS rob
Postby heeman10 on Fri Mar 18, 2011 11:45 pm
Quick random drop-in comment after scanning down this particular page. Firstly, it all looks lovely! Secondly, just thought I'd check you're using fluoro-silicone lined (i.e. oil-dedicated) silicone hose for the oil returns/breathers etc. The hoses used on my engine originally were just silicone water hoses, and they fairly quickly got eaten away and started seeping.
Postby Rhinopower on Sat Mar 19, 2011 12:41 am
heeman10 :Quick random drop-in comment after scanning down this particular page. Firstly, it all looks lovely! Secondly, just thought I'd check you're using fluoro-silicone lined (i.e. oil-dedicated) silicone hose for the oil returns/breathers etc. The hoses used on my engine originally were just silicone water hoses, and they fairly quickly got eaten away and started seeping.
I was about to say the same thing! Lol
Rhinopower
Your car: Volvo FH330
Postby Max M4X WW on Sat Mar 19, 2011 10:13 am
As above x2 :lol:
Postby RS rob on Sat Mar 19, 2011 2:00 pm
it is the special fluro lined hose
one that Ian had made for me
probably be useless if I change the manifold
RS rob
Postby Excursion on Mon Mar 21, 2011 9:58 pm
Work on your loom has started. I sent to the office and had my PA strip off herself and the loom tape. I have located the PATS box.
Postby Rhinopower on Mon Mar 21, 2011 10:12 pm
Mark. Awesome work!
Rhinopower
Postby - Danny Boy - on Mon Mar 21, 2011 10:33 pm
Can we see more pictures? :lol: :lol:
- Danny Boy -
Postby RS rob on Mon Mar 21, 2011 10:34 pm
thats pure filth!!
love it :lol:
RS rob
Postby fezza89 on Mon Mar 21, 2011 10:36 pm
Excursion :Work on your loom has started. I sent to the office and had my PA strip off herself and the loom tape. I have located the PATS box.
:lol: who is that woman???
fezza89
Postby knuckles on Mon Mar 21, 2011 10:46 pm
This forum is getting more and more rude !
boobs keep appearing all over the place :lol:
knuckles
Postby Max M4X WW on Mon Mar 21, 2011 10:56 pm
My PATS box didn't look like that :lol:
Postby GavStyli on Mon Mar 21, 2011 11:04 pm
awsome! :D :lol:
GavStyli
Your car: Fiesta Turbo
Postby jonyb4 on Tue Mar 22, 2011 1:20 am
fine pair of t!ts
wiring is neat too :lol:
Postby Michael! on Tue Mar 22, 2011 11:24 am
Did you take anymore while she was hard at work :lol: ?
ft-com-members-map-vt190192/
Michael!
Postby Excursion on Tue Mar 22, 2011 1:02 pm
The rest aren't suitable for this site :lol:
Postby SEG1 on Tue Mar 22, 2011 5:06 pm
Excursion = PIMP DADDY
SEG1
Postby fezza89 on Tue Mar 22, 2011 5:11 pm
i do like a good boobie :lol:
fezza89
