project "JPH" 2.1 ZT 358bhp-365ftlb : Member's Gallery - Page 25 | Fiesta Forums
Re: project "JPH" 2.1 ZT 358bhp-365ftlb
Postby Smo on Tue Mar 22, 2011 6:51 pm
fezza89 :i do like a good boobie :lol:
You're missing out... Most come as a pair these days :)
Smo
Postby jonyb4 on Tue Mar 22, 2011 7:33 pm
Smo :
:lol: !
some rare little ladies have 3!
Postby jonyb4 on Thu Mar 31, 2011 10:46 pm
any updates mate? im tempted to barge into the workshop at fords to see it, but id get clobbered in doing so :bonkers:
Postby RS rob on Thu Mar 31, 2011 11:09 pm
nope sorry jonny
waiting for mark to remove the pats system from my loom,
then the loom is off to be braided at the same time as the engine harness being done,
once the loom is back the ball will really start moving.................
in the mean time i've got brackets to sort for the coilpack, air injectors and map sensor
also ordered a new exhaust manifold, but i'll say more about that when i have some pictures :)
RS rob
Postby jonyb4 on Thu Mar 31, 2011 11:50 pm
:Q
fords was busy earlier :oooh:
dropped my c.v and was about to order that mirror interior panel, but ill call back for that
Postby Excursion on Fri Apr 01, 2011 1:50 pm
Most of it has gone, I will hopefully finish it today mate.
I hope you don't mind but I have removed a few of the labels as they wee getting in the way. Just call me if you need to know what plugs in where.
Postby Spanish_1.1 on Sun Apr 03, 2011 9:59 pm
Awesome project mate, wich servo/master cylinder is that? Have you had to modify it to fit?
thanks
Spanish_1.1
Postby RS rob on Tue May 03, 2011 8:10 pm
Spanish_1.1 :Awesome project mate, wich servo/master cylinder is that? Have you had to modify it to fit?
thanks
its from an escort i believe,
the rod at the back has been shortened
RS rob
Postby jonyb4 on Tue May 03, 2011 8:15 pm
evening rob, any progress with the Si?
i was expecting to see you on stand with SW-cc at singleton yesterday, i presumed you had to work?
Postby RS rob on Tue May 03, 2011 8:32 pm
been a while since i updated this,
firstly got hold of some extended plug leads so i can move the coilpack
with the big help of luca, thanks mate
next up as the main car loom was looking rather chunky
there were a few things i wanted removed,
mainly the pats system and all associated items to do with it
also the airbag wiring
so i trusted the loom with a good mate (mark stewart)
heres some of the removed wires
next up was dropping the main car loom now its been on a diet to paul cheshire
as i wanted the visable loom in the engine bay covered in braid to match the pectel harness i'll be having soon
with a very quick turnaround, paul has done a pukka job
the blue labels are only temporary incase i have a blonde moment
paul also done my fog/driving lamp loom
it really does freshen up a 15 year old loom
very happy and would reccomend him
RS rob
Postby RS rob on Tue May 03, 2011 8:50 pm
when paul came down to sunny south wales to measure up the pectel engine harness, we spoke about the possibility of one his tubular manifolds
as my current s2 manifold was not only a big restriction on the engine's potential,
but makes things look for tight for room later on for intercooler and radiator
so i've decided to go for it, its tubular with back perge welding that looks spot on
and tasty 4-1 collector!!
heres some pics on pauls own engine, once i have the manifold and decide on the final postion of the turbo, the pipework can be finished from the collector
to the t3 flange
going back to the car loom
when mark was removing things he asked if i wanted the heated front screen removing, as i did'nt realise there was one,
he went on to mention he had a spare heated screen loom
so a deal was done and recieved this today
new heated front screen to be ordered very soon
great to add this to the spec of the car,
not that it will ever be out in the frost haha
RS rob
Postby Excursion on Tue May 03, 2011 8:57 pm
Looking great, mate :D Does this mean you can get her out of the bodyshop now? The car deserves that manifold! Does this mean an instant 400 or does the map need tweaking?
Postby RS rob on Tue May 03, 2011 9:08 pm
Excursion :Looking great, mate :D Does this mean you can get her out of the bodyshop now? The car deserves that manifold! Does this mean an instant 400 or does the map need tweaking?
its on the cards very soon mate,
thanks again
as for the manifold i'm really happy with the decision
i was planning to pop up to harvey's for him to check the map out when its all up and running
but i'll have to have a chat with him soon to see what he thinks,
as with alot less restriction from the exhaust manifold it wont need the boost trimmed down after 4k
RS rob
Postby niracka on Tue May 03, 2011 9:08 pm
Nice. When you say back purge welding what do you mean?? As in they have used backing gas by filling the pipes with shielding gas as they are welded up?? or something else??
niracka
Your car: E46 M3
Postby Dave G fsi on Tue May 03, 2011 9:11 pm
Looking brilliant mate :aviator:
Dave G fsi
Your car: Mk1 FRS and FRST
Postby RS rob on Tue May 03, 2011 9:12 pm
niracka :Nice. When you say back purge welding what do you mean?? As in they have used backing gas by filling the pipes with shielding gas as they are welded up?? or something else??
bunged one end of the tube,
filled with gas and then welded the outside,
with the benefits of the gas keeping the penetrated weld tight and smooth on the inside aswell
so not to cause any restrictions
think i've seen on one of your threads your a proper welder,
so go easy on me if i've got something wrong ha
RS rob
Postby jonyb4 on Tue May 03, 2011 9:33 pm
al sounds good man, how much is the new heated screen costing if you dont mind?
mine is a bit tatty and has a chip :(
Postby RS rob on Tue May 03, 2011 9:35 pm
jonyb4 :al sounds good man, how much is the new heated screen costing if you dont mind?
around £245+vat retail mate
RS rob
Postby jonyb4 on Tue May 03, 2011 9:38 pm
oh it could have been worse then :)
mind a regular wind screen for my first mk3 was only around £140ish :oooh:
Postby niracka on Tue May 03, 2011 9:44 pm
Lol yea I'm a welded/fabricater in raf.
Thats spot on mate you should always use a backing gas on stainless werever possible. Just stops oxidisation and porosity in the weld surface makiing a much stronger longer lasting weld.
Keep up the good work mate :)
Ollie
niracka
Your car: E46 M3
Postby 3lward on Tue May 03, 2011 10:17 pm
That's a sexy fudgekin manifold!
The Fat Fake XR2i
3lward
Postby RS rob on Tue May 03, 2011 10:59 pm
niracka :Lol yea I'm a welded/fabricater in raf.
Ollie
phew i was right :lol:
cheers for the further info
RS rob
Postby RS rob on Tue May 03, 2011 11:08 pm
jonyb4 :evening rob, any progress with the Si?
sorry mate,
just seen this comment,
i've done lots of shows for years with a big crowd of car mad mates
but as we're all growing up times are changing for me,
only go to shows of real intrest to me now
as i'm trying to keep most of my spending for the mk3
rs central day - santapod
rs coombe
ford fair - silverstone
RS rob
Postby jonyb4 on Tue May 03, 2011 11:35 pm
thats understandable mate, im still "young" and living it :P
nah joking need to get the inspiration and motivation really, plus its either that or a sunday/bank holiday in the house eh?
Postby RS rob on Wed May 04, 2011 8:03 pm
some more progress
the main loom is roughly in place
to keep things neat, i've tried laying the loom a certain way
one way involved going through the heater motor cover
so with a bit of modding
got the dash back in which is a nice sight, makes the car look a little more together inside
rear parcel shelf trims back on
also got hold of some new sidelight bulb holders as mine were manky and beyond cleaning
also trimmed the support bracket which holds the throttle cable as it scratched the heater cover
it needs a freshen up but thats something to sort later
before
after
also a quick shot of my rc 750cc injectors
RS rob
Postby Excursion on Wed May 04, 2011 8:09 pm
Did you get the TB through Ian, mate?
You could do with a grommet where the wires pass through the cover :)
Postby FRSJON on Wed May 04, 2011 8:42 pm
all looking great rob :Q manifold looks lovely..please pm the price :D
FRSJON
Postby Dave G fsi on Wed May 04, 2011 10:44 pm
Stunning :Q
Dave G fsi
Postby jonyb4 on Wed May 04, 2011 10:54 pm
again stunning :)
quick question, does the mk4/5 etc iB5 gearbox mount in the mk3 cradle?
i figured you had to weld overhead mounts in like the mk4s have
Postby RS rob on Wed May 04, 2011 10:57 pm
Excursion :Did you get the TB through Ian, mate?
no mate i bought most of paul j's engine setup from a guy called danny in london
whys that mark??
also i'll sort a grommet to stop any chaffing!
RS rob
Postby RS rob on Wed May 04, 2011 11:00 pm
jonyb4 :again stunning :)
not sure as it makes things complicated
my ib5 is from a late escort
RS rob
Postby jonyb4 on Wed May 04, 2011 11:05 pm
ahh the escorts use mounts on the front and back of the gearbox, i guess they do mount in the cradle fine then :)
a handy conversion actually
Postby Excursion on Thu May 05, 2011 12:14 pm
Rob, Can you pleasepost the code for the sidelight bulb holders?
If you have them to hand: the loom clips from the inner wings in the engine bay, and from under the car the fuel/brake pipe & hand brake cable clips?
Postby RS rob on Thu May 05, 2011 5:43 pm
the sidelight bulb holders are no longer available mark
this is where i found some
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
i dont have the part numbers for the other bits yet mark
RS rob
Postby Excursion on Thu May 05, 2011 5:47 pm
RS rob :the sidelight bulb holders are no longer available mark
Thanks mate. Ordered.
