project rs turbo rep.....steel wheels....
Re: project rs turbo rep.....steel wheels....
Postby jonyb4 on Fri Feb 24, 2012 4:42 am
ive seen a red one, best description i can give them is theyre cresent shaped, have a metal bracket and are bolted the the opposite side of the throttle linkage, they have a sliding bar attached thats connected to your throttle, and a triangular multi connector on it
Postby b0yracer on Fri Feb 24, 2012 11:21 am
ok cheers i only ask because sometimes my car revs really high and wont stop like somethings sticking, i changed the sliding plunger thing at the side as it was well caked up and i thought it was that, but still does it some times its very intermitent
so wondered if it was the tps
cant wait to get cvh in on carb and dizzy then ill know what im doing :D
b0yracer
Your car: ford
Postby russ-RST on Fri Feb 24, 2012 11:28 am
xr2ilookalike :ok cheers i only ask because sometimes my car revs really high and wont stop like somethings sticking, i changed the sliding plunger thing at the side as it was well caked up and i thought it was that, but still does it some times its very intermitent
Change the throttle cable, also check your vac pipe that goes from your inlet to the servo when I launch my car hard it pops out and once you let off the throttle it just keeps revving untill the limiter or I turn it off first :lol:
russ-RST
Your car: fiesta rs turbo
Postby jonyb4 on Fri Feb 24, 2012 5:43 pm
lol be at home with a carb and dizzy set up :P
nah smidgy to me it sounds like the TPS thats playing up, find another from another 1.1/1.3, dont go to ford they quoted me £120 for a new one, f**k that
Postby b0yracer on Fri Feb 24, 2012 5:51 pm
i checked the vacuum pipe at the time its not that dont think its throttle cable as i dabbed the pedal several times but it made no difference, it just stopped doing it when it wanted
b0yracer
Your car: ford
Postby fezza89 on Fri Feb 24, 2012 8:50 pm
i had these problems but once i fitted a new idle motor it was sorted
fezza89
Postby b0yracer on Fri Feb 24, 2012 9:04 pm
where and whats that, if anyone got a photo and lable where these bits are im off to scrapy on monday
b0yracer
Your car: ford
Postby fezza89 on Fri Feb 24, 2012 9:18 pm
heres a link with a photo from when i was asking
post1892696/?hilit=throttle position sensor#p1892696
the red thing is the tps and you can just see behind it the plunger of the idle control motor, the tps is bolted to the same bracket as the idle motor which is like a cylinder with wires coming out of the top of it to a plug.
they are located on the right side of the carb under the airbox as you look into the bay, the tps also comes in black :D
fezza89
Postby b0yracer on Fri Feb 24, 2012 9:48 pm
cheers ive gone on over to that thread you put a link up for
so i dont hijack this thread
could you take a look and try help me out on there
im confused
im more old skool plugs n points thats why im going cvh carb n dizzy soon :lol:
b0yracer
Your car: ford
Postby jonyb4 on Sat Feb 25, 2012 12:05 am
mine had eaten through its wire sleeves, the 3 wires were touching and playing havok
Postby b0yracer on Sat Feb 25, 2012 12:07 am
cheers il check the wiring
b0yracer
Your car: ford
Postby jonyb4 on Sat Feb 25, 2012 12:10 am
the TPS is simply a potentiometer and they breakdown inside, giving false readings
Previous
