project rs turbo rep.....steel wheels.... : Member's Gallery - Page 6 | Fiesta Forums
Re: project rs turbo rep****goodies****
Postby rs220bhp on Wed Mar 30, 2011 4:29 pm
Id be in contact with him mate for a refund and if he doesnt cough up then get onto paypal if you used them. They will pass the mot if the adjusters dont work but if there leaking they will fail and also if the spring isnt tight in the platform and cup when the wheels are off the ground that will also fail
As for the bearing, the guy is talking crap it deff sits under the cup like the 2nd and 3rd pics
rs220bhp
Postby fezza89 on Wed Mar 30, 2011 4:41 pm
rs220bhp :Id be in contact with him mate for a refund and if he doesnt cough up then get onto paypal if you used them. They will pass the mot if the adjusters dont work but if there leaking they will fail and also if the spring isnt tight in the platform and cup when the wheels are off the ground that will also fail
ok ill have to get him to change them round, ive asked the bloke for a refund but i aint heard back from him yet. what do paypal do? do they definantly get your money back?
also if i hold on to the tops of the rear shocks, the piston drops down so the spring in loose so i spose that would be an mot failure?
cheers for the help
brad
fezza89
Postby rs220bhp on Wed Mar 30, 2011 5:21 pm
fezza89 :
cheers for the help
brad
What do you mean? When you try to compress the shock it just pushes in really easily? Is there and resistance when you try and do this?
Paypal may be able to get your money back or part of it if the goods are not as described.
rs220bhp
Re: project rs turbo rep****$hit coilovers****
Postby fezza89 on Wed Mar 30, 2011 5:30 pm
i took the spring off and i can push the shock down with no resistance, then i have to pull it back out, seems theres no pressure in them.
i just want my money back now as i struggled to get the money together for them in the 1st place so now im skint.
if i dont hear back from him soon ill go straight to paypal
fezza89
Postby rs220bhp on Wed Mar 30, 2011 6:14 pm
fezza89 :i took the spring off and i can push the shock down with no resistance, then i have to pull it back out, seems theres no pressure in them.
Sounds like there f**cked mate but they will be soft if the set to the softest setting but there should still be a little resistance in them even if there set to soft and they should pop back up on there own.
Id contact them anyway as it takes a few days to sort out a dispute anyway
rs220bhp
Postby fezza89 on Wed Mar 30, 2011 7:16 pm
ok thanks for the advice mate ill get on it now
brad
fezza89
Postby fezza89 on Wed Mar 30, 2011 7:31 pm
stupid question
what do i do on paypal to open a case about getting a refund? ive never done it before?
brad
fezza89
Postby rs220bhp on Wed Mar 30, 2011 7:48 pm
go to the resolution section mate and follow the steps
rs220bhp
Postby fezza89 on Wed Mar 30, 2011 8:19 pm
ok thanks done it now
brad
fezza89
Postby Jay001 on Wed Mar 30, 2011 8:29 pm
well for what its worth, and to settle the argument with your garage here's the diagram..I take it the shocks wernt off anybody from here?
good luck with getting the situation resolved.
Jay001
Your car: Fiesta RST
Postby fezza89 on Wed Mar 30, 2011 8:42 pm
thanks for going to the trouble of getting the diagram photos mate much appreciated.
unfortunately it was a member on here i got them from, i wont name him untill he starts refusing a refund, i will spill the beans so noone else gets screwed over tho. it was the fact he has lied about the condition that gets me
fezza89
Postby jonyb4 on Wed Mar 30, 2011 9:16 pm
the shocks should be nice and stiff pushing in and pulling back out
and ill add my 2pence worth that the bearing sits under the cup on the mk3
Postby jayrs on Wed Mar 30, 2011 9:42 pm
depending how you have the springs set will depends if the piston has enough moment to allow the spring to become loose.
its a shame your having problems mate :(
the windy gun should of taken the nut off, the force and speed of it spinning should be enough to undo the nut from the piston due to resistance within the shock, did he get the nut off ok?
Postby fezza89 on Wed Mar 30, 2011 9:50 pm
yep it is a shame, hopefully i can sort some new suspension before fitp
yeh the bloke in the garage had a bit of trouble getting the nut off but it came off eventually.
i think ill go back to square 1 with a new gmax kit.
hopefully it'll all be sorted with no more problems
fezza89
Postby jayrs on Wed Mar 30, 2011 10:44 pm
your giving up on the coil overs?
Postby Fraggle on Wed Mar 30, 2011 11:33 pm
:bonkers: Morning,,Lookin Good Fella:wink: Soz Too Hear About Your Troubles Geeze,Some Propper Feckends Out There :rolleyes: Give Him 7days Too Refund Ya,If He Dont Go Have A Holiday On His DoorStep,Take A Friend Too(Any Suggestions As Too Which Friend He Should Take With Him Gents??)Me Thinks a Light Sabre:wink:
Good Luck Fella And Keep Goin Dont Let The Ba5tard Get Too U :wink:
Fraggle
Postby Jay001 on Wed Mar 30, 2011 11:48 pm
I find it dissapointing that somebody off here would sell you anything knowing they are faulty and in poor condition...
as above 7 days and then name n shame......
Jay001
Postby Fraggle on Thu Mar 31, 2011 12:10 am
:bonkers: As Above,,,Patientce is a virtue So Allow Him Time To Be a Gent an Sort It :wink: If Not...Then As Above,But Remember Too Amend If He Sorts It after Hes Named...They Can(Very Very Rarely..)Change There Spots If There Cool :wink:
Fraggle
Postby fezza89 on Thu Mar 31, 2011 6:20 pm
if a different decent set of coilovers come up jay id get them but otherwise it will have to be gmax kit,
as said ill give him a chance to refund, hopefully he'll be ok with it
fezza89
Postby jonyb4 on Thu Mar 31, 2011 9:52 pm
fudgekin s**t luck mate
what a tool, i hope he genuinely had little knowledge of them and didnt know they were on theyre arse end
Postby jonyb4 on Thu Mar 31, 2011 9:53 pm
yet again it be cheaper to service/repair them than buy another set of shocks/springs mate
or maybe service them and sell them on
Postby fezza89 on Fri Apr 01, 2011 2:51 pm
im guessing he would want them back if he gave me a refund
fezza89
Postby fezza89 on Fri Apr 01, 2011 2:55 pm
on a lighter note.... i had the day off work today so i took the car down to the body shop to get booked infor next saturday,
ive ended up getting them to paint the bonnet,front bumper,both wings and both front arches
so im hoping the next update will be that ive been refunded for the coilovers and pictures of the front end finished :D
fezza89
Postby russ-RST on Fri Apr 01, 2011 3:47 pm
if he has not mentioned about you sending the coilovers back buddy i would keep them and get them refurbed when u got the money saves, him selling them on to another person in "good working order" :rolleyes:
russ-RST
Your car: fiesta rs turbo
Postby fezza89 on Fri Apr 01, 2011 3:49 pm
smidydevil :if he has not mentioned about you sending the coilovers back buddy i would keep them and get them refurbed when u got the money saves, him selling them on to another person in "good working order" :rolleyes:
yep thats true, wouldnt like to see someone else done over like i was
fezza89
Postby fezza89 on Mon Apr 11, 2011 7:09 pm
dropped the car off at the bodyshop tonight on the way home from work :Q
fezza89
Postby jonyb4 on Mon Apr 11, 2011 10:59 pm
wooop, cant even remember what your getting done lol
Postby fezza89 on Tue Apr 12, 2011 10:39 am
bonnet both sides, front bumper both wings and both front arches :D
fezza89
Postby Jay001 on Tue Apr 12, 2011 2:14 pm
Have you heard off the guy you got the coilovers from yet? is he giving you your money back?
Jay001
Postby fezza89 on Tue Apr 12, 2011 2:55 pm
nope he is ignoring all my messages :x i think im hitting my head up against a brick wall with him
fezza89
Postby Michael! on Tue Apr 12, 2011 3:00 pm
you not got his address?
go and gammon slipper him :D ?
ft-com-members-map-vt190192/
Michael!
Postby fezza89 on Tue Apr 12, 2011 3:07 pm
:lol: i would but he lives in devon and im in dagenham
fezza89
Postby jonyb4 on Wed Apr 13, 2011 12:33 am
ha well do it and raid his wallet for the petrol fee :lol:
Postby Jay001 on Wed Apr 13, 2011 10:41 am
Id be tempted to name and shame mate..and tell a staff member on here aswell..not that it gets your money back but it may stop him selling faulty goods through here again...spend the little extra and get them refurbed..at least then they are usable.
Jay001
