putting cossi 2 wheel drive 4 pots on a fiesta ?
13 posts • Page 1 of 1
just wondered if anybody could tell me what i have to do to fit these ? do i have to drill the hub out or space the caliper ? cheers
- luke_mk3_st
- luke_mk3_st
Re: putting cossi 2 wheel drive 4 pots on a fiesta ?
you need to drill the hubs and use spacers and longer studs.
also mondeo v6 disks.
- SEG1
ok cool. why do i have to use the mondeo discs ? thanks
- luke_mk3_st
- SEG1
ooo ok. becuase at the moment i have hi-spec 4 pots 285mm discs "cosworth" i think. on my fiesta but fitting wheels is a pain and when i do get wheels on the front they stick right out. what diamater are the v6 discs ? also thats the only reason i was going to put the cossi brakes on because i thought i would give me a better offset for my wheels.
- luke_mk3_st
the mondeo v6 discs are 278mm.
- SEG1
- luke_mk3_st
you also need custom made hoses
- SEG1
o realy. what are the connections diffent at both ends compared to the fiesta ones.
- luke_mk3_st
just at the caliper end.
they have to be a 90degree banjo connection .Burton do them
- SEG1
are you selling the hi spec kit then??
- dug112y
if i can get the cossie brakes then ye i should be selling the hi-spec kit. a set exactly the same sold on ebay the otherday for £670!!!!! but they had bells and rotars, were i just have cossi discs. so i thought mine are worth £400 thats with goodridge hoses to. but like i said if i can get some cossi brakes.
- luke_mk3_st
