QUEST FOR TRUTH PLS HELP !!!!
10 posts • Page 1 of 1
WILL a set of spax shocks and springs off an rs fit a fiesta si with power steering koni say yes but they are spax so im in the air the backs will just unsure why the front would be much different cheers people
- HCS PIMP
Re: QUEST FOR TRUTH PLS HELP !!!!
if the koni's fit so will the spax.
- matty872
if its fit a post 92 car (a mk3.5 after K) then yes.... if its a off an RS turbo (or any pre 92 car) then no!
- xrsi
- XR(ustyAtTheMo)SI
cheers guys getting my spax at the end of this month then drop my car on it ass and that way it will stay till i get my 2.0 engine sorted
thanks again welcome to drive it when im finished and its track ready or race it
- HCS PIMP
surely a 91 plate fez rs spax kit will fit if i throw the hubs on toooo and new shafts
- HCS PIMP
HCS PIMP :will mk3 not fit mk3.5
mk3 parts will not fit mk.5 hubs.
if you want to use mk3 shocks on a mk3.5 you will need to swap the following from the mk3 as well .....
front hubs
both drive shafts
lower arms
lower arm carriers
simply not worth the hassle as mk3.5 is a better stronger design. hence why ford changed it.
- knuckles
- Your car: Fiesta Rs turbo
lol okies that makes sence probs just use the springs if not ill sell them as they arent spax shocks they are record
- HCS PIMP
you can fit them, it just needs a small spacer to work, i did it with mk3 avo's onto a mk 3.5,
- Ruishy1
cheers the sort responde i wanted well illl see tomorow how possible it is afte rmakign my bike and going to the scrappy
- HCS PIMP
