Question fiesta turbo
Postby Kayrus on Sun Jul 26, 2015 1:44 am
hello I have a fiesta turbo whit injectors 701, double capacity IC , gasoline pump Cosworth , T3 turbo, need to know that Phase 2 Superchips chips need not be if Magneti Marelli or amal , Check how it is? thanks
What if someone sends a Spain . I would be forever grateful to him , I feel the words , I have been using the translator Gogle
This next week will begin to reconstruct gradually. If you accept me in your Forum . I hang pictures from my little house and my new rs turbo from Spain
Kayrus
Your car: Fiesta turbo
Re: Question fiesta turbo
Postby Kayrus on Sun Jul 26, 2015 10:53 pm
there has not been much interest in my problem , but I have good news . OFAB purchased chip 195 and actuator t3.
I'll need a tap to regulate gas pressure ?
I read that the regulator of fuel rail is modified to give more pressure .
I appreciate any input. thanks
Kayrus
Postby russ-RST on Tue Jul 28, 2015 8:18 am
There is a circular cap ob top of the fuel pressure regulator , this can be removed and then inside is a way to adjust he fuel pressure to allow you to get the AFR ratio correct , not sure what your other question was asking ?
Russ
russ-RST
Your car: fiesta rs turbo
Postby Kayrus on Tue Jul 28, 2015 10:12 pm
okay. Thank you. my frst has a Phase 2 , and I don`t know if I have valve AMAL
I leave a link if you can help me:
chip-195-ofab-which-manages-the-amal-valve-vt196742/
Thank you man :wink:
Kayrus
Postby Kayrus on Tue Jul 28, 2015 10:17 pm
I have little time on this, and I am a bit lost
Thanks from Spain
Kayrus
Postby russ-RST on Thu Jul 30, 2015 6:19 pm
The Jamal valve is on the drivers side inner wing (uk drivers side) by the air filter, it looks like a black circular box has 2 pipes coming off of it and a 2 pin plug that plugs into it see if you have one fitted if not i do have a spare I wouldn't mind selling to you cheap if it helps ... hope I've helped what you were after?
Russ
russ-RST
Postby Kayrus on Tue Aug 04, 2015 3:51 am
ok, Thursday I go to the garage to work on it. And I write a message.
to upload photos easily like?
thanks man
Kayrus
Postby Kayrus on Tue Aug 04, 2015 3:53 am
and if mu fiesta brings no amal valve? What should I have?
Kayrus
