quick guide to fitting the Xr/RS skirts and arch kit
Postby jonyb4 on Wed Sep 29, 2010 9:35 pm
Hi, started spraying my XR skirts and arches ready to fit them to my Si, a few of the studs are missing from the arches.
ive heard a good way is to use fords plastic coated rivets, ive found remains of some on the kit
basicly which is the best way? preferably best long lasting hold but easy to apply
how do i fix the arches? and how to fit the skirts? rivets and new studs? sound expensive as a ford dealer is involved
or do i use sealers, but seem more difficult to use
im not very good with cosmetics as in fibreglass or tiger seal etc, truth being ive never used either :rolleyes:
any help is appreciated thanks :)
Re: quick guide to fitting the Xr/RS skirts and arch kit
Postby fezza89 on Wed Sep 29, 2010 10:12 pm
my kit had all the studs missing so i used a body kit glue i bought from a paint speciallist,
applied it over the insides of the kits arches then used strong tape to hold them in place over night, worked perfect,looks the part and sets rock solid so it wont go anywhere.
just have some white spirit on hand with a cloth incase you get the glue on the paintwork.
for the skirts i just used self tapping screws for the top and bottom, holds them perfect.
fitted mine about 4 years ago and aint had no problems at all.
hope this helps
brad
fezza89
Postby jonyb4 on Wed Sep 29, 2010 10:34 pm
thanks alot mate do you know of a name of this glue you used?
did uyou take any measures to protect the sills from rust
ive though about maybe using some number plate screw caps over these screws i have a few lieing around
Postby fezza89 on Wed Sep 29, 2010 10:39 pm
i can get the name for you 2moro ive still got some in the garage.
yes i completely cleaned my arches inside and out and the same with my sills
you could use some hammerite or rust preventor on your arches and sills before putting the kit on that would help with rust.
brad
fezza89
Postby jonyb4 on Wed Sep 29, 2010 10:43 pm
Postby fezza89 on Wed Sep 29, 2010 10:45 pm
yep that stuff will do the trick,
if you have any problems pm me n ill help where i can
brad
fezza89
Postby jonyb4 on Wed Sep 29, 2010 11:25 pm
ok cheers for the great help mate
:Q
Postby jayrs on Thu Oct 07, 2010 10:42 am
theres a guide by me in the guides room for restudding the arches mate
Postby b0yracer on Sun Oct 10, 2010 10:37 pm
im planning on doing this soon.
got some parts already, waiting on some to arrive, will be sticking my arches on too as the studs are all missing, will buy some of the adhesive in the link above
b0yracer
Your car: ford
Postby jonyb4 on Sun Oct 10, 2010 11:25 pm
im gonna also try and use that boind to glue a stud inplace to help hold the arch on, at least one per arch to bolt through one of the Si holes
Postby Tweek on Sat Nov 20, 2010 3:13 pm
Body Kit Glue, now there's an idea, shall make a note of that for the new year :D
Your car: VW Golf GTD
Postby jonyb4 on Sat Nov 20, 2010 4:53 pm
Lol what
