quick question
3 posts • Page 1 of 1
quick question
whats the best battery i can get for my si?
any particluar barnds?
- danfezSi
Dunno...try and find one that has BOTH terminal covers. I recently bought a Varta one (supposedly very good) but it only came with one of the covers! I rang Varta and tried to get one specially, but they just don't supply them So if you get one, and you can't find one with both covers, keep both the ones off your existing battery...only a problem if you're a fussy baxtered like me
I would use Exide, Varta or Ford/Motorcraft.
I'm using a 540amp type 092 Motorcraft silver/calcium one
its pysically bigger than the std fiesta ones, fills the whole battery tray.
only down side is it makes the air filter even more of a Whore to change
I know james, most batterys seem to come with no covers these days I had to cut up a negative cover to fit on the + side although you can order new ones from ford still AFAIK.
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
- Maff Si
- Your car: Nothing til end of the month
