quick spacer/saftey Q...
7 posts • Page 1 of 1
just a quicky - whats the most i can space out my wheels with out usuing longer studs etc... i already have 5mms on the backs and was looking to stick another 3mm spacer on...is this gonna be safe or not really...
cheers,
ade
cheers,
ade
- Faith
are you doing this to stop rubbing or for looks? If it is for looks I would suggest against it as having 8mm spacers is a lot and is pushing the wheels out a lot, also you may start getting rubbing on the outside arch which i started getting when i had spacers on the back of my car.
- AC 2003
as above for sure, and i just happen to have some nice bits of 4mm steel the same shape as the stub axle in my shed as i was gunna do this then i got coilovers
i didnt need spacers but then i got rear disc's so it spaces out anyway.
the drum has to come off to get the 2 rivets out that hold the back plate to the axle, take the drum off, take the 4 bolts out the back (prob have to drop the axle off shock) and take stub axle off, drill out the 2 rivets, the back plate is now only held in place by the brake line so be careful, slip ya spacer up the back of the back plate and bolt the stub axle back on (might need longer bolts) so you have spacer, back plate, stub axle, then stick the drum back on and jobs done mate
you cant use wheel spacers for this, you have to make one up mate
