Rasing the rev limit?
8 posts • Page 1 of 1
I talked to a Swedish engine tuner and he said it was possible to raise the rev limit simpy by soldering in a new crystal with a 10% higher clock frequency in the ecu? Anyone tried this??
- volvia99
Hi m8, don't know wether thats a good idea, as the rev limiter is there to stop you over revving your engine and doing internal damage. Unless of course your engine has been built to cope with the extra pressure.
- MikeyXR2i
I talked to the guy who helped me with my head, I would be ok to go to at least 8000 RPM. Titanium coated valves and lifters
http://www.roadster.se/Bilder/Zetec134.jpg
- volvia99
According to him 8000 RPM was on a standard bottom end, but using ARP con rod bolts, and those mod i mentioned earlier. I do trust him since he buildin enginge for Formula Ford in Scandinavia.
http://www.elwamotors.com
- volvia99
Im amatuer guessing that it's better to hav the ECU programmed to overide the standard limit so the fueling, timing, etc. will be correct for the extra revs the standard ECU wont be programmed 4.
I know that a performance ECU chip allows u to raise the rev limit in a Clio Williams/16v so would imagine the EMS r similar.
- MIK3Y
