Rear discs and brake bias???
31 posts • Page 1 of 1
Whats the deal then, basically i got some rs2k items that need fitting as soon as i can but the only thing that is worrying me is the bias thingy
Ive heard that it will need a bias valve fitting to alter the braking proportions then ive also heard that it should be ok without
Also will i need a different master cylinder at all?
Thanks in advance
Thanks in advance
- MOONDUST FRST
i run rear disks without changing the bias valves that a mk3 has on the inner wing! they dont lock up or make the back step out so no need for me to use an extra bias valve!, im not saying every car will be the same tho.. but wouldnt of thought u would!
however you will need to uprate the servo as it is s**t with rear disks on! no feel at all!
get one from an escort and follow the guides that have been posted on how to fit them
- xrsi
- XR(ustyAtTheMo)SI
Yep as said follow get the Escort brake cylinder and servo to keep proper pedal feel. Will help your fronts greatly too as well
However after I put rear discs on mine I found the back stepping right out in wet conditions and one time I came out of a corner going backwards!
Worth testing them out in a carpark somewhere and adjusting them.
- Stoned
Ka_Rst :if you just leave the brake bias valves that are already on the back it will be fine, the brake servo will stop ok but it will feel a bit spongey
will braided brakes line not help
My Bad!
Sorry
Sorry
- Fiestasi-Andy
- MOONDUST FRST
Here goes, When you fit Bigger calipers on the front, you increase the bore size of the Piston, hence needing more fluid to push the piston out, but the standard master cylinder can cope with this.
But.... when you fit rear calipers, you now have 2 more calipers to fill up with fluid, as when it was standard with wheel cylinders in the drums, they only needed a squirt full to push the cylinders out, but now with the calipers more fluid is needed, and because the master cylinder is not big enough, you lose pedal pressure.
- MikeyXR2i
As mikey says
When I fitted my rear discs I had no brakes at all until I fitted the Escort cylinder. I had to take the car off the road. That was using Mondeo V6 calipers on the front and Granada rear calipers
- Stoned
Hmzzzzzzzzzz fitted front and rear disks from RS2K and didn't swap te master cilinder and got good brake balance and feel in the paddle
Did i do something wrong then or got just lucky
I am driving it for about 6 months now and it still feels good even on track as i heat them up big time
The only sponge feeling i got was when they where new and i had to bed them in for the rest they are perfect and i am not ass lifting under heavy braking
greets Tazzie
greets Tazzie
- Tazzie
interesting
, what master cylinder do u have? was the car orignally a turbo etc?
btw im guessing urs is LHD so has no bar?
- fiesta_fras
- Elite Poser
If have i Fiesta XR2I from 90 and the master cilinder is the standard one
I didn't upgraded it as i didn't upgrade the servo
I got 260mm front discs(RS2000) and at the rear i got the RS2000 rear break setup and it works fine
If you wanna find out what the car looks like take a look at the link below
http://www.fiestaturbo.com/phpBB/photog ... ery&u=5498
greets Tazzie
greets Tazzie
- Tazzie
Yeah I had a RS2k setup before and it was also fine, only a little bit of a squashy brake pedal.
But Mondeo calipers and granada rears are much larger and take a lot more fluid which is why the brakes dont work properly
- Stoned
Pedal travel is fine with the RS2K setup. The front pistons aren't much larger than standard so providing you've got good condition pads and dsics all round it's not too bad
- chumkila
- Dirty Post Whore!
chumkila :Might have to changed mine too then. Lets see how it goes firsty hey.
You got cossie fronts going on mate?
- chumkila
- Dirty Post Whore!
- chumkila
- Dirty Post Whore!
Hmm best bet will be to fit them then see how it goes from there methinks I got cossie fronts and RS2k rears so.......
If i need to upgrade the servo and cylinder which escort one do i use?
- MOONDUST FRST
thats what i used mate!
mk6 1.6 one was the best looking one i found! had to change the master cylinder tho, the seals went so brakes jammed on!
stops really well now!
- xrsi
- XR(ustyAtTheMo)SI
Thats freaky!
Thats exact same thing happend to mine. £55 new from Motorfactors by the way in case anyone wanted to know
- Stoned
tis well freaky!
prob because the car had sat in a scrap yard for a while and the seals had become solid and perished! and plus the fact they were having to do more work all of a sudden!
but my cylinder was cheaper than urs
- xrsi
- XR(ustyAtTheMo)SI
I have same problem with my Turbo.
Get really spongey feel from pedal despite braided hoses - will be putting uprated master cylinder once funds allow (anybody wanna buy FRST parts off of me? )
- andyhardy
