Rear shock lower bush removal FRST
Postby ben47771 on Thu Jul 18, 2013 12:04 am
One of my lower bushes in the rear shock is badly worn so need to replace i have 2 brand new genuine Ford bushes but have never done these before, do they need to be pressed out and new ones pressed in or can it be done by hand? I might as well replace both while im at it the other one has probley seen better days aswell! I am running Avo coilovers if this makes any differance, its a 1990 FRST.
Cheers in advance people.
Ben
Old Fords Never Die; They Just Get Faster!
Drives: Fiesta RS Turbo, Zetec turbo. Ford Transit Crew cab tipper 2012. 2005 Audi A4 1.9 TDi 130 Sline
ben47771
Your car: 1990 Fiesta RS Turbo
Re: Rear shock lower bush removal FRST
Postby Simon84uk on Fri Jul 19, 2013 1:00 pm
Think my avo's had poly-bush ones fitted. If that isn't standard then maybe they are available. I would think they could be forced in by hand though, plenty of lube. It's getting them out that will be tougher, either burn them out or use a makeshift press from a vice or a large threaded rod and some washers using large sockets/steel tube.
But to be honest if the bushes are that worn on the avo's then they will probably be well overdue a rebuild so I'd send them off and get them to do it all...
Si.
1991 Fiesta RS Turbo - Project Thread - 285.8bhp, 320ft/lbs - Sold to a good friend :cry:.
Your car: Fiesta RS Turbo
