Rear Speaker Adapters
Postby ~ John Reid ~ on Wed Jan 24, 2007 6:54 pm
Ive got some autoleads rear speaker bracket/adapters - the instructions are not clear as there just pictures and no text (the pictures are in black and white and unclear).
can anybody shead any light on how to fit them ?
~ John Reid ~
Postby goaty on Wed Jan 24, 2007 6:57 pm
can you get a pic? i ahve some and can explain if you have a pic for it. Thats if there the same as mine.
goaty
Postby ~ John Reid ~ on Wed Jan 24, 2007 7:21 pm
yea just scanned it on here.
the quality is apalling of the pictures so you will have a hard time seeing it.
~ John Reid ~
Postby goaty on Wed Jan 24, 2007 7:31 pm
right there the same aa mine so i will have a go at explaining.
the TOP RIGHT pic shows you which way it has to go in, there is a bit of plastic on the back side which slots in as the original speakers do, then you pu t screws in the other end to hold it up. The screws go up in the long screw holes (tubes), you have a pair on each side, as shown in the pic. One on each side of the adaptor will fit up in the original speaker screw holes.
Once its fitted in ,the speaker has to slot in two corners into the adaptor. On the adpator you should see there is space for two corners of the speaker to slot in, then the other side of the speaker just has two screws holding it in.
sorry if its not clear but it shoudl help you.
let me know if you have more probs and i can try and help more.
good luck with it
goaty
Postby ~ John Reid ~ on Wed Jan 24, 2007 7:51 pm
cheersd will have another go tomorrow, you say the screws go up in the tube bits - do the screws come with the adapters or do you use your own.
and also on the car there isnt anywhere for the screws to hold onto apart from the plastic which is about 3 mm thick??
~ John Reid ~
Postby Tweek on Wed Jan 24, 2007 8:55 pm
goaty :right there the same aa mine so i will have a go at explaining.
good luck with it
You found my instructions then :lol:
Your car: VW Golf GTD
Postby goaty on Wed Jan 24, 2007 11:26 pm
no, lost them ages ago, but got a good memory.
goaty
