Removing Cat ...
5 posts • Page 1 of 1
Removing Cat ...
Hello all,
I am having many problems with my Powerflow exhaust at the moment. The backbox is fine, but the pipe between the cat and the backbox keeps dropping down (not powerflow), which results in the backbox vibrating on the rear valance. I have it booked up for Saturday once again and I was thinking about having the pipes from the manifold - cat - backbox replaced with a new one and get rid of the cat. My car requires it but I am not sure how to go about doing it.
Shall I get the cat cut open and a pipe put inside through it for the chance of on the spot emission test by the plod?
Or shall just get the pipe straight through with no cat?
How will both options effect the Lamba Sensor and is the sensor needed?
Cheby
Cheby
- cheby
You want to increase about 4-5hp loosing the cat??? Well here in Argentina you can do it and get away with it BUT as I have read, in England the MOT is much more strict than here and since the gas test is made by a machine you will fail.
It is a bit stupid to open a cat and place a piece of piping inside. Just ask the exhaust guiy to put a piece of pipe where the cat goes and keep the cat so you can put it when you have to go through MOT.
Consider taht if you remove the cat the gases will flow faster and therefore the lambda sensor will not get as hot as it should and will missread. Your car will run a bit richer.
Fahr nicht schneller als dein Schutzengel fliegen kann
- FedeArg
FedeArg :You want to increase about 4-5hp loosing the cat??? Well here in Argentina you can do it and get away with it BUT as I have read, in England the MOT is much more strict than here and since the gas test is made by a machine you will fail.
yea but when you do take it to MOT just stick standard exhaust on, easy.
they are cheap in the scrap
1995 Fiesta SI 3 door, green something, 2L + diesel gearbox in(130mph @ 5,000rpm ), focus inlet in, + k&n, passed mot without a cat < FIESTA FOR SALE! GOT A BMW 528I SE MANUAL NOW
http://www.finalgear.com
- VUK
Ok. I was intending in keeping the cat if I had it removed, which I would probably do. But it is on its way out anyways so that is why I wasn't too worried about cutting it open and gutting it. Only thing is if I dont have the cat on at all and get pulled over and they do an one the spot emissions test I will be buggered (read that on here, not sure if it true?). However if I had it on and gutted I could then say I wasn't aware of it.
Where would the lambo sensor go if I had a straight through pipe from the manifold to the backbox?
Cheby
Cheby
- cheby
VUK :FedeArg :You want to increase about 4-5hp loosing the cat??? Well here in Argentina you can do it and get away with it BUT as I have read, in England the MOT is much more strict than here and since the gas test is made by a machine you will fail.
Thanks, I forgot to write that
- FedeArg
