Removing Emissions Recirulation Thing?
9 posts • Page 1 of 1
My Si, has the emissions recirulation thing on the exhaust manifold, I have heard there can be a power gain from removing it?
So what needs to be done? what do I need to plug the holes on the manifold?
Will it cause any MOT emssions problems?
What will the power gain be?
- Percy!
- Your car: Citreon
we told u how to do that the other night percy and yeah you do get a power gain from it because it doesnt recurculate the carppy gasses that cant get thru your cat it obviously works better if you have a de cat pipe
- twistedtomo
T'is easy to to remove the Air pulse system apart from being a bit fiddley to get the system from round the manifold and the radiator gets in the way a bit.
o Undo the system from the manifold
o Do the fiddley bit as above
o Put washers and blanking plugs into the manifold and do up tightly
o Then for the vacuum hoses, I chopped it back to near the solonoid and plumbed it back into the inlet manifold.
Seems to work for me and its been like it for ages now.
Part Numbers:
Blanking plugs - FINIS 6732263
Copper Washers - FINIS 1008597
Roger can get them: roger@fordpartsuk.com
HTH
Part Numbers:
HTH
- krsi
twistedtomo :we told u how to do that the other night percy and yeah you do get a power gain from it because it doesnt recurculate the carppy gasses that cant get thru your cat it obviously works better if you have a de cat pipe
Thats why I am getting more info on the actual procedure.
- Percy!
- Your car: Citreon
how many blanking plugs and washers are needed? might try this on my little project car for a laugh..
- bcracknell
This might seem harsh but it is fresh in the tuning section at present. And has been in tech probs too I beleive.
- Phil Si
Car: 2000 BMW 330 Ci
