Removing tape player for mk4 1.3 lx fiesta
6 posts • Page 1 of 1
Tried getting 2 screw drivers in there and yanking it out but no luck, is there an easier way to get it out to fit a new cd player?
- rankinator
yeah there is....stop being tight and go to halfords or similar and buy the keys (pins) to put in the holes and pull!
- marcus_m01
as said, use the proper pins! if you are too tight to buy them (like I am, they're £10 in halfords!) then pop to your local garage and they should have some you can use (if you ask nicely of course!).
Don't forget you'll need a wiring adaptor, these are about £12-£15 from halfords...
- Chris 2i
marcus_m01 :yeah there is....stop being tight and go to halfords or similar and buy the keys (pins) to put in the holes and pull!
About 2 quid in Motorworld. Cheapest I found.
- properphatboy
- Your car: Peugeot 306 D L
I went and got em from halfords (4.95, the cheek!) and go tit off fine, but now I need to get some converters to go to the new cd player which are a tenner
Also, when its fit in I obviously have a space above the player (as its not as big as the original tape/radio player) what do you advise I put in its place? Just cut out some plastic or something?
- rankinator
theres autoleads parts that use that space i think there around £15.
http://www.halfords.com/webapp/wcs/stor ... ryrn_31494
it will look like this afterwards :
( Picture of Guy Mk4's stereo )
- ~ John Reid ~
