Results of the NOS...
14 posts • Page 1 of 1
I have been out for a run and i know it isnt the most accurate way of timing, but i used a stopwatch. well it wasnt actually me but a friend timed me.
I managed 0-60 in 7.2 seconds, and if anyone downgrades this time for an Si i will personally injure them severly...
I used a 50 shot of nitrous and it picked up pretty damn good.
I know i have no proof of this, but if you dont believe me then dont... dont really give a rats ass,
cheers, A.
cheers, A.
- Wude Si 16v
7.2 is pretty rapid for a n/a car, how much did the whole setup cost including fitting etc? and u declared it to ur insurance?
i personally would spend my money on a turbo conversion. but then i have no money!!!
- Canwell
Saw this on the RSOC... Bring it, don't sing it
You should bring it to the R&R day ?
ps im not saying i dont believe ya
- Andy Si
Wicked nice one
Hmm Nos
Dave.
Hmm Nos
Dave.
7 Years and on my 5th Car, Fiesta 1.1i, Saxo VTR 98bhp, Bmw 318is Coupe,C2 VTS and now a 1998 Toyota Supra
- dr_blackman
- chumkila
- Dirty Post Whore!
the whole thing cost about £700, to be honest with you i wish i had gone for a turbo conversion. i am always scared that my bottle will run out so i dont want to use it as much.
by the way, it is nothing like fast and the furious, even though they are running 100 jets.
the next stage is 75 brake jets... who's ya daddy....!! nitrous baby!!
cheers, Adam.
cheers, Adam.
- Wude Si 16v
How can u get it to go in at the right time mate? have u got a progressive controller or summit? like if it all came in from idle to 7000rpm i can see traction being a big problem! can u have it so that it comes in at 3k or so? I know u said u fitted a button for it, but was that to 'arm' and 'disarm' the nitrous, so to speak, so u not always using it when goin around town etc, or was it just to turn it on and release it into the fuel system like fast and furious?
Am interested in this mate and sounds like a stormer at the mo. Good work mate
Jon
Jon
- festajon
the way it works is there is a microswitch which you place near the throttle arm in the engine, when you floor it the throttle arm hits the microswitch and turns the nitrous on. this doesnt fire it just arms it, then you have a switch in the car which you press to release the NOS , it only stops firing when you either take your foot off the throttle or take your finger off the firing switch,
hope this has made it a little clearer,
Adam.
Adam.
- Wude Si 16v
Wude Si 16v :the way it works is there is a microswitch which you place near the throttle arm in the engine, when you floor it the throttle arm hits the microswitch and turns the nitrous on. this doesnt fire it just arms it, then you have a switch in the car which you press to release the NOS , it only stops firing when you either take your foot off the throttle or take your finger off the firing switch,
Adam.
could u rig it up the other way, so u arm it with a switch, then when u floor it, it then releases the NOS - so it works similarly to a turbo.?
- Canwell
you can rig them up how you want really, you could do what you say about the on/off switch, but there is no point activating the NOS unless you are flooring it, it would be a waste of nitrous.
- Wude Si 16v
sound good 7.2- 60mph is possible ! when you think a saxo vts does it in 7.8 std
just i think it is poss and if not put the 75bhp jets in and it WILL ! #
jeff
jeff
- lazy_arse_pie
i reckon 7.2 is possible, but like you said a stopwatch is'nt the most accurate way of timing things
but who can afford proper timing gear anyways?
Newsflash : Jeremy Beadle has a small penis. but on the other hand, it's massive.
- Muzza
Wude it wouldnt be a waste of nitrous mate as if your foot wasnt on the floor it wouldnt be active!
7.2 seems reasonable for a stop watch attempt...beleive me though when you use proper timing gear your time will be slower...(same for everyones not just saying yours there btw )
- PF Dave
