Rev Counter from RS Turbo or 2i
Postby Max M4X WW on Mon Jun 17, 2013 8:49 pm
Hi all,
I have two sets of clocks/rev counters and neither are reading properly on my OFAB car. One is blank and one is 2E.
I need some from an RS Turbo ideally or possibly a 2i? It needs to have the pointy needle and plastic back, not metal. Obviously I will buy the whole dial set as I don't expect anyone to split!
Thanks, Max
Postby Pastieman on Tue Jun 18, 2013 7:28 pm
I have a set from my Rs matey and worked fine before I broke it ???
[/url]
Pastieman
Your car: Mk3 Fiesta Rs Turbo
Re: Rev Counter from RS Turbo or 2i
Postby Max M4X WW on Tue Jun 18, 2013 9:31 pm
Sounds great, given that I'm quite fussy and I will be looking at them every time I drive it what sort of condition are they in?
Postby mikeymikeyp on Tue Jun 18, 2013 9:47 pm
Have you not tried to run a wire to the edis , seems to sort that problem most times
mikeymikeyp
Postby Max M4X WW on Tue Jun 18, 2013 11:15 pm
I haven't no, I will try the other set I have but they read higher than the ones in there now but not high enough I don't think.
Postby russ-RST on Wed Jun 19, 2013 5:21 pm
If your still looking for a set iv got a set that came out of my original rs turbo. I'm using mk4 clocks now so no need for them. Worked perfectly fine when I removed them
Russ
russ-RST
Your car: fiesta rs turbo
Postby Max M4X WW on Wed Jun 19, 2013 6:36 pm
Any chance of a photo? Cheers!
Postby russ-RST on Wed Jun 19, 2013 11:38 pm
Will get you one tomorow :)
russ-RST
Postby Billyfiestars1 on Sat Jun 22, 2013 7:34 pm
I have a set of 150mph clocks
Billyfiestars1
Your car: Fiesta rs turbo van
Postby russ-RST on Sun Jun 23, 2013 1:06 pm
There you go fella
Russ
russ-RST
Postby Max M4X WW on Mon Jun 24, 2013 4:41 pm
They look great, being anal but should they not say CVH on them or EFi? I assume if they have come from your RST they will be fine. Is it OFAB or OFAC?
Postby russ-RST on Mon Jun 24, 2013 10:50 pm
I don't know mate iv never looked :rolleyes: it was ofac mate worked fine in my car untill I changed to mk4 clocks. Through choice may I add
Russ
russ-RST
Postby Max M4X WW on Mon Jun 24, 2013 10:56 pm
I need to confirm OFAB and OFAC clocks are the same and last question - how yellow are the needles?
