rev gauge issue
rev gauge issue
Postby gazaboi on Tue Jun 03, 2014 12:05 am
right got the fiesta all back together now after its rebuild but i did have an issue that had started before my rebuild and still seems to be there where the rev gauge jumps to 2000rpm when i turn the key sometimes higher and this is without the engine running, it seems to work fine when the engine is running though just wondering if someone has had the same problem or point me in the right direction to sort this out
gazaboi
Your car: fiesta rs turbo
Re: rev gauge issue
Postby georgiocat on Tue Jun 03, 2014 8:36 am
Have you noticed if the rev counter "jumps" when you switch on and off a high load? For example, if you have powered windows and the engine running, if you press the window switch, usually for closing, does the rev needle move? Usually such problems are ground point issues, check the ground points and cabling around dashboard and instrument panel.
My Ford Escort ride
georgiocat
Re: rev gauge issue
Postby gazaboi on Sun Jun 08, 2014 3:05 pm
yeah it does move when electrical loads increased mainly with the electric window or i think indicating does it too, i dont know where to check or where the earths are behind the dash, my fuel gauge is a little tempermental aswell dont know if its related
gazaboi
Re: rev gauge issue
Postby AW3K on Mon Jun 30, 2014 10:01 pm
hi are you using the correct clocks for the car?
are you using a suppressor on the rev counter?
more info on both here
http://www.fiestaguides.co.uk/content/r ... w_sup.html
AW3K
