RS 2000 rear brakes
RS 2000 rear brakes
Postby whitedragoon on Mon Apr 29, 2013 9:22 am
I got rear rs brake conversion on mk3 and planning to change rear beam with twin arbs and do general all unit refurb. Before starting would like to get some useful information.
does the wheel bearings remain the same after conversion? And which company would be better to get? im thinking about SKF.
Is the handbrake cable fitted from RS2000 or left original?
whitedragoon
Your car: mk4
Re: RS 2000 rear brakes
Postby fezzRS on Tue Apr 30, 2013 9:36 pm
I have rs2000 disc conversion you you will need the rear rs200 hubs bolt straight on then i need the calipers discs and ye u need the rs2000 handbrake cable but leave the yoke on for the firsta
Your car: run about
