RS Rear window Nuts Rust
Postby Ice 159 on Mon Sep 02, 2013 12:10 pm
Hi Guys,
Just wondering if there is a solution or a write up to this problem?
Regards
Ice 159
Your car: 1990 Fiesta RS Turbo
Re: RS Rear window Nuts Rust
Postby Whitterz on Mon Sep 02, 2013 4:28 pm
The three nut covers you mean? I managed to get the rust run down the window stain off with a clay bar
Whitterz
Your car: Fiesta RST, Astra SRI
Postby Ice 159 on Mon Sep 02, 2013 8:19 pm
Yes mate, I cannot seem to remove them. Even the screw from the inside won't budge. Any further ideas? Someone suggested drilling them out?!
Ice 159
Postby Whitterz on Mon Sep 02, 2013 8:40 pm
I've only just picked up my RS, thats been stood for 3 years. 2 pairs of grips might work ?
Whitterz
Postby RS EDDIE on Tue Sep 03, 2013 12:19 am
Remove rear windows and soak the sandwich nuts in wd40 a few times.
Cover a pair of pliers with electrical tape around the jaws.
Place window between your legs kneeling down, and peel the inside rubber caps off.
Hold this side of the nut with a fat headed phillips screwdriver.
Grip the outer dome with the pliers tight.
With max pressure to the phillips, turn ( anti clockwise) against the tightly held outer dome.
They should begin to spin apart. :D
RS EDDIE
Postby Ice 159 on Tue Sep 03, 2013 11:32 am
Good Man I will give that a go ! :)
Ice 159
Postby andymac on Fri Sep 13, 2013 7:53 am
Ideally soak in wd40 or deblocking oil for a period of time before attempting to disassemble, it doesn't penetrate immediately (unfortunately!).
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
