rs1800 ecu in 1.8 xr2i
3 posts • Page 1 of 1
Thinking of getting hold of an rs1800 ecu and MAF sensor for my 1.8 xr2i.
Aswell as needing an rs1800 maf to go with the ecu, will I also need the corosponding lockset and keys? It's just the MAF sensor that'll need replacing too, all the other sensors will talk to the the rs1800 ecu?
- KoalaPlushie
Re: rs1800 ecu in 1.8 xr2i
Nobody any idea? Been trauling through previous threads, and aparantly the cult ECU isn't compatible with all years of 1.8 xr2i.
- KoalaPlushie
I'm sure you will only need the lockset/chip if the ECU is taken from an RS1800 with PATS.
If you take the ECU from a Mk3 RS1800 you will be fine.
Also you will need the cams, HO Inlet and Throttle Body from a RS1800.
- fiend
