RS1800 K&N 57i Induction Kit
16 posts • Page 1 of 1
Does anyone know if the xr2i 16v 57i kit will fit & work correctly on the RS1800, as K&N dont list a 57i kit for the RS1800
- ANDY B
Re: RS1800 K&N 57i Induction Kit
ANDY B :Does anyone know if the xr2i 16v 57i kit will fit & work correctly on the RS1800, as K&N dont list a 57i kit for the RS1800
I don't see why not, after all the xr2i 16v is just a de-tuned RS1800 engine so should be the same.
1995 Ash black 1.4si-SOLD
1992 White xr2i 16v-SOLD
On the hunt for another 2i 16v or a tubby
- tomcat404
I believe the filter is a bit smaller on the xr2i but all in all it should work fine!
I have parts for sale!!!!.....Nice parts too!!!
http://www.fiestaturbo.com/forums/lots-of-parts-for-sale-vt185591/
- MattPym
filter size dont really make a difference anyway unless your pulling in massive amounts of air
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
MattPym :I believe the filter is a bit smaller on the xr2i but all in all it should work fine!
Really?! What a complete waste of time and energy designing a different filter for essentially the same car!
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Re: RS1800 Induction Kit
Many thanks for quick replies, what induction kits are people using on there RS1800's then. I rung K&N & they said the reason why they dont make 57i kit for the RS1800 is either that there was not enough call for them or they tried 1 & it made no power increase.....
- ANDY B
I use a pipercross power sock. If they do one for the 2i 16v use that if you really need to get one, it's exactly the same fitment.
- Ollybee
I think you would be better off with a escort zetec one as there bigger i was using one on my frst and the fitment was very close i got a bigger green cotton one from a seat and stuck my old N&N on the mrs escort all you have to do is meassure the end of the filter as long as it's with 2mm you will be ok
- j7aoc
The code for the 57i kit for a xr2i 16v 1.8i is: 57-0156 and the code for the escort mk6 1.6 16v is : 57-0156 and the same code for the 1.8 16v escort and it's the same for the fiesta 1.6i 16v
- j7aoc
j7aoc :I think you would be better off with a escort zetec one as there bigger i was using one on my frst and the fitment was very close i got a bigger green cotton one from a seat and stuck my old N&N on the mrs escort all you have to do is meassure the end of the filter as long as it's with 2mm you will be ok
you state that the escort one is bigger, yet its the same part no as fiesta kit. the fiesta si 1.6 16v is part no 57-0158 so is a different kit, pipercross actually list one for RS1800. Ramair are listing a kit for 1.6/1.8 16v escort & fiesta but dont state which exact models they fit. This is doin me head in all i want is an induction kit for my RS1800..................
- ANDY B
I got my one from ebay it was new with no box the guy said it was from a zetec but im not sure it fit's a zetec very well K&N list 2 fiesta 1.6 16v zetec ( long intake pipe & cone filter) 1995 is 57-0156 the fiesta 1.6 16v zetec ( long intake pipe & panel filter) is 57-0158) I know my K&NANDY B :j7aoc :I think you would be better off with a escort zetec one as there bigger i was using one on my frst and the fitment was very close i got a bigger green cotton one from a seat and stuck my old N&N on the mrs escort all you have to do is meassure the end of the filter as long as it's with 2mm you will be ok
- j7aoc
j7aoc :I got my one from ebay it was new with no box the guy said it was from a zetec but im not sure it fit's a zetec very well K&N list 2 fiesta 1.6 16v zetec ( long intake pipe & cone filter) 1995 is 57-0156 the fiesta 1.6 16v zetec ( long intake pipe & panel filter) is 57-0158) I know my K&NANDY B :j7aoc :I think you would be better off with a escort zetec one as there bigger i was using one on my frst and the fitment was very close i got a bigger green cotton one from a seat and stuck my old N&N on the mrs escort all you have to do is meassure the end of the filter as long as it's with 2mm you will be ok
I see a 57-0156 kit on ebay yesterday for £45 new but no box, but seemed reluctant to sell it to me for my RS1800 as K&N dont list it for my model
- ANDY B
On the RS1800 (and 2.0/1.8 MONDEO mafs ), the left side of the MAF is bigger than the 1.6/1.8 16v engines.
The KnN kit comes with a crossover pipe, the MAF end is the right size for 1.6/1.8 16v engines.
Too make it fit, heat up the end, lets say with some boiling water, and stretch it out by inserting a glass bottle around the same size as the MAF.
Let it set with glass bottle in there, then smash the bottle. Now attach pipe to MAF
Throttle body end is the same for 1.6/1.8/2.0.
Hope this helps.
Hope this helps.
Fiesta Mk3 2.3 Duratec Turbo - GT28RS Custom Most Stuff....
http://www.fiestamk7.com Dedicated Fiesta Mk7 Forum
http://www.fiestamk3parts.com Fiesta Mk3, Info/Guides
- cookie456_the2nd
THANKS VERY MUCH FOR LETTING ME NO ABOUT THIS ON THE 57I KIT. SO THE PIPERCROSS KIT THAT LISTS XR2I 16V & RS1800 AS SAME KIT SHOULD FIT AS YOU USE YOUR EXISTING CROSSOVER PIPE, CORRECT
- ANDY B
JUST FOUND A GROUP A RAMAIR INDUCTION KIT DESIGNED SPECIFICALLY FOR RS1800 £100 !
- ANDY B
cookie456_the2nd :On the RS1800....the left side of the MAF is bigger than the...1.8 16v engines.
Is that what you are trying to say cause they are the same sensor! They use the same MAF.
- Ollybee
