RS1800 spec
18 posts • Page 1 of 1
RS1800 spec
hay jus bought 1800 xr2i n wanna change it 1800 spec cud i jus use rs1800ecu n 2.0l cams n throttle body? wud tht do the same job
thanx alot
thanx alot
- Stokesy_y2k
I would use the cams, throttle body and ecu from a 2.0L as they are cheaper to find.
Though only a couple of early 2.0L Mondeo ecus can be used on the Fiestas!
Hope this helps!
Dan
Hope this helps!
Dan
- DanS2i
- Location: Northampton Drives: Like A White Van Man Should!
I think all Mondeo 2.0 ECUs have internal EDIS whereas your XR2i 16v almost definitely will use external EDIS, so you would need to use an early RS1800 ecu. I think the code is 2FDC, but hopefully someone will confirm that.
- Smo
- chumkila
- Dirty Post Whore!
ok if i cnt use the 2.0l deep ecu n rs1800 r hard 2 source wot other alternatives do i have? got cams n throttle already?
- Stokesy_y2k
ive got a mk1 2.0 in my rs1800. i spent hundreds trying to get a 2.0 ecu to work and taking it to tuners etc. basically theres no chance of running a 2.0 ecu on a rs1800 loom unless you change the loom to an Si one. rs1800 ecu are hard to find. you could have a look on ebay for rs1800 breaking.
- dee_RS_2ltr
can sum1 help as the conversion is goin thru soon, wot benifit wud i have using xr2i maagment first instead of rs1800?? wud i get [ERRR] gains
- Stokesy_y2k
Theres not much difference in the two ECU wise (RS1800 and XR2i 16v)
Do the following:
2.0 Cams
2.0 Throttle Body
2.0 MAF Sensor
Remove the EGR
At worst get a cat back exhaust - if you can get a decat too!
I spent ages researching this and messing about with various bits and bobs
Do the following:
2.0 Cams
2.0 Throttle Body
2.0 MAF Sensor
Remove the EGR
- SimonT
