rs1800 turbo?
15 posts • Page 1 of 1
rs1800 turbo?
can i use my original ecu? i have a 1995 rs1800 which i am turboing hopefully,just getting bits and pieces and finding out as much info as possible,i have been looking at the zetec turbo sites for hours,i have learnt alot,just stuck a bit when it comes to ecu and injectors? i only want to run about 180bhp so it is still reliable ish! any help would be great!
- rs1800/m
you won't be able to use the rs1800 ecu cos it won't know whats happening when the turbo kicks in - you will need a fiesta turbo ecu of some sort.
Excursion and Project are masters on this topic (amongst many others), take a look at their sites.
- Wude Si 16v
Use a FRST ECU. U dont need to change ur injectors or inlet manifold if ur only going for 180 brake.
- chumkila
- Dirty Post Whore!
What are the flow rates on the Zetec injectors Chum?
Have a look at http://st2000.s5.com/fzetecturbo.html - it should get you thinking
- Project
- fiftyoneCL
- AndyRS1800
Project ST2000 :What are the flow rates on the Zetec injectors Chum?
I dont know Proj. So ur research tells u, u will need to change injectors?
- chumkila
- Dirty Post Whore!
cheers for the replys still need to find out more about the wiring and injectors,i have owned 2 escort turbos before so i know most of the mechanical side of things,but just a bit stuck with ecu+injectors,i might be best to use the fiesta turbo inlet manifold and injectors and get a adapter plate made up,i would prefer to use mine as it already fits,any more info about making up a custom injector rail on my inlet manifold so i can use the end fed injectors? any info on this would be great the more the better cheers
FIESTA RS1800,1.8 zetec!
- rs1800/m
because i will be blocking the front breather off because of the t3,would it be possible or ok to put a breather coming from the top of the sump just below the block? it will be alot easyier than drilling and tapping into the block itself thats all?i know i have to put a oil return in the front of the sump!
- rs1800/m
Yep, you can do that - see http://www.fiestaprojects.com for more info on where to place these breathers
- Project
- fiftyoneCL
ok tanks mate,very helpfull! i still dont know what inlet manifold to use,i am trying to decide,if i use the frst ecu and wiring can i use my inlet manifold? or is it best to use the frst inlet manifold?
- rs1800/m
