rs1800
5 posts • Page 1 of 1
rs1800
hi all
ive managed to pick up a salvage rs1800
how much work is there involved in putting the engine in my 1.6si
i have read the threads on modeo 1.8 and 2'0 but just wondering if its diffrent for the rs1800 block
thanks
ricky
thanks
ricky
- rickyjay86
Re: rs1800
hi mate just had my converion done! you will need some parts off your the si thou! u need the wiring loom off the rs1800, the edis module, ecu and maf! its a straight in jobby really it uses the same part nums for most things and u dont need to fabricate mounts or anything pretty easy really
- tommy g
Re: rs1800
ive heard i can use the si loom is that possible
- rickyjay86
Re: rs1800
If you have an RS then I think the cheapest/easiest thing to do would be a complete loom change. Swop the RS car + engine loom into the Si. The reason I say do this is because you could use the Si's loom however you would need to search for a CULT ecu which are like rocking horse s**t and command top dollar. Therefore I'd swop the loom. If you plug any other 1800 130ps ecu into the Si engine loom it will not work and changes are it will blow the ecu as well.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Re: rs1800
is that the only option as i cant find any cult ecu anywhere, and not the best when it comes to wires??
- rickyjay86
