RS500 calipers
9 posts • Page 1 of 1
RS500 calipers
anyone fitted these to a frst,
by my theory they go under 15's as the rs500 had 15's as std and should be better than the usual 1 pot setup,
any advice, info much appreciated
still need to update this sig
- ~Tony~
Are they differen't from normal 3 door's Tony? Never heard mention of them being any different that's all...
so rumour has it they are 4 pots on the RS500 and as they fit under the std rs500 15's they should fit under mine.
dunno if 3 doors had the same brakes but sure i have heard mention of rs500's having 4 pots
if anyone can shed any light would be great
- ~Tony~
TonyBlackFRST :so rumour has it they are 4 pots on the RS500 and as they fit under the std rs500 15's they should fit under mine.
I think most if not all of the 2WD's had 4 pots mate, they can be made to fit but will require an Escort master cylinder.
Scort did the conversion to his Escort: http://www.rsbible.co.uk/
We will need 4x4 discs though I think, as the 2wd offset is incorrect fo Fiesta use.
Excursion :TonyBlackFRST :so rumour has it they are 4 pots on the RS500 and as they fit under the std rs500 15's they should fit under mine.
Some of the later 2wd's had 2-pot's if i remember correctly
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
They are the same as all the other 2wd calipers. As mentioned you'll need the discs off a 4x4.
I'm told that they aren't actually as good as the single pot sliders on the 4x4s so I wouldn't pay any extra for them. There's more to a good caliper than the number of pistons.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
i was going to have Scorts off him but discussing it with him, would not only need different disc but huge spacers on the calipers too.
and the icing on the cake was the fact they weigh a ton apparently
worth ago if you got them hanging about but not if you got to buy them IMHO
- FezzR
- God Damn Lazy
