RST, XR2i, Si - SUSPENSION INTERCHANGEABLE???
9 posts • Page 1 of 1
Hi just wanna know if the Rst, Xr2i suspension kits will fit the Si? because there's so many kits widelt available for the xr2i/rs and they all have anti-roll bar connections etc.
So they should be interchangeable right? can anyone confirm this? Thanks in advance!
(liking the new server/site)
- E4Fiesta
Re: RST, XR2i, Si - SUSPENSION INTERCHANGEABLE???
All Mk3 Fiesta suspension is interchangable the only issues are when you start to bring the Mk3.5 into the mix as the front struts are of a larger diameter than the Mk3.
Yours being an Si may cause problems as most were Mk3.5 and I can't think of any companies that offer a quality kit. I would be inclined to change the hubs to Mk3 items and anything else required for the conversion to open the avenue to a whole host of decent kit.
Damn, is that so?
I thought id heard of a few people using the other suspension. and kits on ebay etc say from 89-95, so i expected all sizes were the same.... although some say (except rs & xr2i) but i presumed that was because of anti-roll links.
- E4Fiesta
sorry to steal the post but how can you tell if you have mk3 or 3.5 hubs?
- bankxi
What about...
Bilstein Sprintline 35mm spring and damper kit for 1.4-1.8/XR2i year 01/94 - 12/95
Eibach Pro-Kit 30mm Springs 1.0, 1.1, 1.3, 1.4, 1.6 year 02/94 - 01/96
H&R do Sports Spring Kits so do Spax, Pi etc.
just go by KYB/Bilstein/Monroe/Gabriel Gas dampers or ones from ford to go with any of the Spring Kits
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
- Maff Si
- Your car: Nothing til end of the month
bankxi :sorry to steal the post but how can you tell if you have mk3 or 3.5 hubs?
If you have a 93>97 L to P Reg Mk3 (classic shape) fiesta that came with oval side repeaters, filler cap flap & smaller type wing mirrors it will be a MK3.5 so should have MK3.5 Hubs, I say should because if you have a very early one it may have MK3 hubs!
- Maff Si
So would rear suspension from a Si fit on the rear of a 1.1/1.3 Mk3.5 fiesta?
They must have the same hubs at the back.
- E4Fiesta
E4Fiesta :So would rear suspension from a Si fit on the rear of a 1.1/1.3 Mk3.5 fiesta?
Yes. Plus the standard Si setup is exactly the same as the RS1800.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
You the man!
- E4Fiesta
